J090_SC88T_test_program_2019-04-08.zipLatest source codeZip Archive - 128.12 kB - 05/07/2019 at 01:54 |
J090-U9.PLDFirst attempt, compiles but unproven so far.pld - 4.07 kB - 03/17/2019 at 20:48 |
J090-U11.PLDFirst attempt, compiles but unproven so far.pld - 2.58 kB - 03/17/2019 at 20:48 |
J090-U11.lstLogic compiler output.lst - 4.36 kB - 03/17/2019 at 20:48 |
J090-U9.lstLogic compiler output.lst - 7.00 kB - 03/17/2019 at 20:48 |
J090_SC88T_19040-8-E-6969_hexdump.z80Source that assembles using the on-line assembler https://www.asm80.comNote this just contains byte and string definitions, no mnemonics Z80, 8088 or otherwise. It was just created to check the string data. z80 - 148.41 kB - 03/02/2019 at 21:15 |
J090_SC88T_19040-8-E-6969.hexFirmware that came with the board, in Intel hex file format.x-hex - 77.03 kB - 03/02/2019 at 20:40 |
J090_SC88T_19040-8-E-6969_hexdump.cBinary converted to C array using the Linux commandxxd -i -c 16 J090_SC88T_19040-8-E-6969.bin x-csrc - 196.11 kB - 03/02/2019 at 20:40 |
J090_SC88T_19040-8-E-6969.binFirmware that came with the board.Resides in the last 32K of the 80188 memory map i.e. at F8000 hex. octet-stream - 32.00 kB - 03/02/2019 at 20:40 |
J090-U11.JEDProgramming data for IC11.jed - 2.94 kB - 02/24/2019 at 20:28 |
J090-U11.EQNIC11 decompiled.eqn - 743.00 bytes - 02/24/2019 at 20:28 |
J090-U9.JEDProgramming data for IC9.jed - 2.94 kB - 02/24/2019 at 20:28 |
J090-U9.EQNIC9 decompiled.eqn - 877.00 bytes - 02/24/2019 at 20:28 |
Arcom_J090_SC88T.pdfUser manual. NB my board is version 1 issue 3, and the manual is for board version 2 issue 5. The latter has the SCC in a PLCC44, and has EMC components (chokes on the RS232 lines, reset input, power rails etc).Adobe Portable Document Format - 647.04 kB - 10/24/2018 at 23:34 |
Keith
