ASSIST-09-faded-output-LV.txtDisassembly of the ROM data read at low VCC. Believed to be better than the one read at normal voltage, but has not been tested.plain - 127.00 kB - 03/26/2026 at 04:06 |
ASSIST-09-faded_info-LV.txtInformation for disassembling the ROM data read at low VCC.plain - 5.24 kB - 03/26/2026 at 04:05 |
ASSIST-09-faded-xor-hd.txtXoring the two ROM images, there are 457 bytes with just d0 different, 39 with just d1 different, and 10 with both d0 and d1 different.plain - 7.78 kB - 03/24/2026 at 05:00 |
x-diff.txtComparing the hex dump of the ROM at normal and minimum VCC, it is clear that the readable ASCII text is corrected, making me confident that the executable code is also much improved. Though there is still the risk that some bits have faded beyond recovery. Hopefully those are few enough to be deduced be educated guesswork.plain - 21.92 kB - 03/24/2026 at 04:28 |
AM2732A@DIP24.BINASSIST-09-faded.BIN ROM read at minimum VCC, on a hunch that this would lower the internal bit-reading thresholds to give faded bits a better chance of being read.octet-stream - 4.00 kB - 03/23/2026 at 20:26 |
ASSIST09step02 (2).txthex dump edited to assemble on asm80.com online.Sections are recognisable as code from assist09 source code. plain - 47.11 kB - 03/18/2026 at 16:04 |
ASISST09step01 (1).txta hex dump of the ROM, read and not editedplain - 22.82 kB - 03/18/2026 at 16:04 |
ASSIST-09-faded.BINoctet-stream - 4.00 kB - 03/18/2026 at 16:08 |
SSI4351_b5.txtSteve Marsh's mystery ROM disassembly so farplain - 60.75 kB - 10/03/2024 at 02:06 |
SSI4351_b5.nfoA few bits of information for the disassemblerx-nfo - 9.05 kB - 10/03/2024 at 02:06 |
SSI4351_b5 Memory Map.txtplain - 1.48 kB - 10/03/2024 at 02:42 |
SSI4351_b5.BINSteve Marsh's mystery ROMoctet-stream - 4.00 kB - 10/01/2024 at 01:19 |
J070-U11_EQN.txtInitial analysis, NOT TESTED!plain - 1.69 kB - 05/28/2022 at 16:18 |
J070-U10_EQN.txtInitial analysis, NOT TESTED!plain - 2.36 kB - 05/28/2022 at 16:18 |
J070-U9_EQN.txtInitial analysis, NOT TESTED!plain - 1.41 kB - 05/28/2022 at 16:18 |
J070-U11-EQN.txtoutput from jed2eqnplain - 887.00 bytes - 05/28/2022 at 16:17 |
J070-U10-EQN.txtoutput from jed2eqnplain - 1.11 kB - 05/28/2022 at 16:17 |
J070-U9-EQN.txtoutput from jed2eqnplain - 883.00 bytes - 05/28/2022 at 16:17 |
J070-SC09-V1I2-U11-MMI-PAL16L8A-CS4BD6.jedjed - 2.76 kB - 02/11/2022 at 02:47 |
J070-SC09-V1I2-U9-PAL16R6-CS4778.jedjed - 2.76 kB - 02/11/2022 at 02:47 |
J070-SC09-V1I2-U10-MMI-PAL16V8H-25-CS58A1.jedjed - 2.96 kB - 02/11/2022 at 02:47 |
Arcom_J070_SC09.pdfUser manualAdobe Portable Document Format - 488.01 kB - 12/22/2021 at 00:46 |
Sys6809.src.txtSource code for Acorn System One 6809 board.Potential foundation for Acorn-based software projects, such as a 6809 second processor firmware and BBC BASIC. plain - 42.33 kB - 03/03/2024 at 16:24 |
6809_SINTB.s.txtBuffered Interrupt-Driven Input/Output Using a 6850 ACIA.From Leventhal's 6809 Subroutines book. plain - 11.19 kB - 09/13/2019 at 21:07 |
Acorn_200_012_U4_works_commented_asm.txtSource code for Acorn's System One 6809 board firmware.Acorn style MOS and monitor, with code to bootstrap from floppy disc. plain - 42.44 kB - 03/03/2024 at 16:24 |
ExBasROM.asm.2019-06-01.zipExtended BASIC for Grant Searle's Simple 6809 design, modified syntax so it can be assembled online. One-byte error corrected.Zip Archive - 63.03 kB - 06/02/2019 at 16:13 |
Keith
