W022_CPM80_manual_for_SCPUB.zip
CP/M manual for the SCPUB. I don't have the software for this, but the manual will give you an idea of how it worked. Grant Searle's CP/M source files might be a good place to start from if porting CP/M to the SCPUB. The SCPUB required STEbus memory to run CP/M, but that might be avoided if the SCPUB is hacked to support bigger RAM chips.
Zip Archive -
2.43 MB -
02/10/2019 at 16:27
Download
W029_EAMONB_for_SCPUB.zip
Manual for a monitor that ran on the SCPUB. I don't have the source code or binary image for this.
Zip Archive -
822.54 kB -
02/10/2019 at 16:26
Download
Arcom_AB80_32K_BASIC-source-DTR-handshake-2019-01-17.zip
BASIC hacked so DTR drives RTS buffer to control the flow of incoming characters. You can copy and paste programs into terminal windows.
Zip Archive -
383.41 kB -
01/17/2019 at 23:02
Download
AB80_Multitasking_BASIC_Compiler.zip
Partially reverse-engineered source code to generate a 32K ROM BASIC compiler. Includes an excellent manual in html form. If you find anything that maybe a typo, consult the manual bearing scans of the original manual.
Zip Archive -
3.18 MB -
11/25/2018 at 21:54
Download
Arcom_SCPUB.zip
Manual, circuits and unaltered logic equations.
Zip Archive -
850.55 kB -
11/18/2018 at 23:11
Download
J041-U19.EQN
Original PAL equations - address decoding. Maps two 8K ROM chips at 0000 up, and two 2K or 4K RAM chips at FFFF down.
eqn -
2.25 kB -
11/18/2018 at 18:15
Download
J041-U13.EQN
Original PAL equations - main control logic.
eqn -
1.66 kB -
11/18/2018 at 18:15
Download
