Disintegrated LM3909 - 1.5V LED Flasher
A clone of National Semiconductor's LM3909 IC using discrete components on a PCB.
There are many projects whose sole purpose is to flash an LED using a single battery. Many of them rely on a 555 timer or a low power microcontroller such as an ATTiny. But did you know there was an integrated circuit created just for this task? National Semiconductor's LM3909 is a "monolithic oscillator specifically designed to flash Light Emitting Diodes". It operates from a single 1.5V battery and would still boost the battery's voltage to 2V even when the battery falls as low at 1.15V.
Unfortunately, these IC's are no longer manufactured and becoming harder to find. They sell for approximately $10 on the secondary market, if they can even be found. Lucky for us, the schematic for the IC is printed in the data sheet, so I was able to rebuild it using discrete components on a small form factor PCB. The BOM cost from Mouser is only $2.70 and parts can be had for about $1 if sourced from China. My PCB can even hold the (originally) external capacitor and LED
This project originated from a #Makevember tweet where I mentioned that I couldn't get my 555 circuit to flash an LED with the power from a coin cell battery. Chip replied with the tip about the LM3909 and I started doing some research on that part and found an interesting article where someone explained how the chip works. (Also refer to this simulation and this page for more details on the LM3909 and this page for some history on the chip). I set the project aside, but only two weeks later, Hackaday announced the Coin Cell Challenge and I knew I had to use this project for my entry. To my knowledge, nobody has ever recreated this IC on a PCB before.
I started by drawing the schematic based on Rob's design in KiCad and finding suitable parts. I wanted to use parts from Seeed's Open Part Library to keep costs down and not have sourcing issues. Most parts are on the OPL, but the uncommon resistor values, the headers, and the large capacitor are not. I chose to use surface mount 2.54mm headers to keep costs down, but Flip-Pins would be nice to use to mimic the IC look. Using default values, the external capacitor needs to be 150uF to have a 1Hz flash rate. This is a lot of capacitance for a 1206 surface mount part, so it adds about $1 to the BOM. An external capacitor in another package size would greatly reduce the overall BOM cost.
I also designed the circuit so it can be used in either the two-transistor current mirror configuration or with one-transistor and a resistor. The one-transistor version saves a few pennies but only works at 1.5V. This is fine for my design since I chose to use this project only when powered by a coin cell battery, but this does break full compatibility with the data sheet voltage range of 1.5 - 5V.
Originally, the circuit could work with only 4 components: the LM3909 IC, a battery, a capacitor, and an LED. It can be assembled to match the original IC and be a drop-in replacement or it could be assembled to be a standalone circuit. I already mentioned that I added a large capacitor to the PCB, and I also added a 0805-sized pad for the LED. With my PCB, everything is on board except for the power source. This configuration is great for making self-contained flashers and I could make a version that is the size of a coin cell battery holder and have a very compact, inexpensive LED flasher which could be great for something like LED throwies.
I laid out the circuit with all electronic components on one side and the pin headers on the other side. The headers are spaced so they match up exactly with the original LM3909's 8 pin DIP. The PCB size is 21.1 x 14.1 mm, which is about three times as large as an 8 pin DIP package. I chose to use mostly 0805 and SOT-23 components to make it easy to assemble, but I'm curious if I can make it match the original 8 pin DIP size if I use smaller packages like 0402 and SOT-883.
I ordered the PCBs from Oshpark and assembled two of them for testing. The first was made in the two-transistor configuration and included the LED and capacitor on board. I soldered this version to a coin cell holder and used a CR2025 battery, This circuit flashed for about a week. The second board was made in the one-transistor configuration and the LED and capacitors were external. This version lasted for about 5 days. The capacitor probably had a higher ESR and the LED may have drawn more current, or it could've been the transistor mirror was less effective. Unfortunately, these tests were not very scientific and I know the batteries were at maximum capacity before powering this circuit. It's safe to say these will last for a couple days, and can probably be adjusted to last even longer.
As a final note, this circuit is a great, modern replacement for the LM3909. You know exactly what you're getting because it's open source (you're not buying a perhaps counterfeit IC from the secondary market) so you can change...
Discrete Version Of The LM3909 Oscillator IC.pdf
Adobe Portable Document Format - 184.38 kB - 01/03/2018 at 00:54
Preview
LM3909 Datasheet 2.pdf
Adobe Portable Document Format - 149.25 kB - 01/03/2018 at 00:54
Preview
LM3909 Datasheet 1.pdf
Adobe Portable Document Format - 481.28 kB - 01/03/2018 at 00:54
Preview
View project log
  • 1
    Buy PCB from Oshpark
    Link in components
  • 2
    Buy parts from Mouser
    BOM listed in components
  • 3
    Use BOM to install components
    D1 is the LED and C1 is the external capacitor from the data sheet. Components can be installed on the PCB or connected externally.
    ConfigurationQ2AR10
    2 transistor current mirrorInstall0 ohms
    1 transistor current supplyDNI330 ohms
View all 4 instructions
zakqwy wrote 01/15/2018 at 20:23 point
I miss the LM3909!
Sascha Grant wrote 01/05/2018 at 02:10 point
The LM3909 was one of the first ICs I used back in my Teens :)
Dave's Dev Lab wrote 01/03/2018 at 04:58 point
Nice looking project! great documentation!
oshpark wrote 01/03/2018 at 04:02 point
Great project!
