I choose to do the packs, since it is all useful bits and pieces and no matter how many of those darn pack of nuts, bolts screws, etc i buy from HF etc i never have the right ones. These quantities are for individual part quantities, and not boxes. $293.50 before shipping and taxes, or about $69 if you buy in the actual part count.
1 | pack | 95475A572 | Zinc-Plated Steel Fully Threaded Stud, 1/4"-20 Thread, 8" Length, packs of 10
| Monday morning | $13.04 pack | 13.04 | |
2 |
pack | 95475A576 | Zinc-Plated Steel Fully Threaded Stud, 1/4"-20 Thread, 10" Length, packs of 5
| Monday morning | 8.26 pack | 8.26 | |
3 |
pack | 98055A099 | Metric Spring Steel Shim - DIN 988, 1.0mm Thick, 5mm ID, 10mm OD, packs of 50
| Monday morning | 8.62 pack | 8.62 | |
4 |
each | 6061K31 | Hardened Precision Steel Shaft, 1/4" Diameter, 12" Length
| Monday morning | 5.21 each | 5.21 | |
5 |
each | 6061K415 | Hardened Precision Steel Shaft, 1/4" Diameter, 14" Length
| Monday morning | 6.16 each | 6.16 | |
6 |
pack | 9600K22 | Push-in Grommet, 1/2" ID, 1" OD, 3/32" Thick for a 3/4" Diameter Panel Hole, packs of 50
| Monday morning | 9.54 pack | 9.54 | |
7 |
4 each | 62805K31 | High-Cap Leveling Mount with Zinc-Plated Steel Stud, 10-24 x 1-1/2" Thread Length, 1-3/16" Base Diameter
| Monday morning | 1.98 each | 7.92 | |
8 |
each | 1764K42 | Steel Angle Ring with 6 Holes, 4" Duct Diameter, 9/32" Hole
| Monday morning | 4.31 each | 4.31 | |
9 |
pack | 91420A320 | Metric Flat Head Phillips Machine Screw, Zinc-Plated Steel, M5 Size, 10mm Length, .8mm Pitch, packs of 100
| Monday morning | 4.05 pack | 4.05 | |
10 |
pack | 96659A101 | 18-8 Stainless Steel Type A SAE Flat Washer, Number 4 Screw Size, 5/16" OD, .02"-.04" Thick, packs of 100
Monday morning | 2.96 pack | 2.96 | |
11 | pack | 97416A115 | Black-Oxide Steel Type A SAE Flat Washer, Number 10 Screw Size, 1/2" OD, .03"-.07" Thick, packs of 100
| Monday morning | 3.82 pack | 3.82 | |
12 |
pack | 90631A003 | Zinc-Plated Grade 2 Steel Nylon-Insert Hex Locknut, 2-56 Thread Size, 1/4" Width, 9/64" Height, packs of 100
| Monday morning | 3.45 pack | 3.45 | |
13 |
pack | 90631A005 | Zinc-Plated Grade 2 Steel Nylon-Insert Hex Locknut, 4-40 Thread Size, 1/4" Width, 9/64" Height, packs of 100
| Monday morning | 2.55 pack | 2.55 | |
14 |
pack | 90257A411 | Type 316 Stainless Steel Machine Screw Hex Nut, 10-32 Thread Size, 3/8" Width, 1/8" Height, packs of 100
| Monday morning | 9.00 pack | 9.00 | |
15 |
pack | 94945A205 | Grade 8 Steel Nylon-Insert Thin Hex Locknut, Zinc-Yellow Plated, 1/4"-20 Thread Size, 7/16" Wide, 13/64" High, packs of 100
| Monday morning | 6.70 pack | 6.70 | |
16 |
pack | 90576A104 | Metric Zinc-Plated Steel Nylon-Insert Locknut, Class 8, M5 Size, .8mm Pitch, 8mm Width, 5mm Height, packs of 100
| Monday morning | 4.18 pack | 4.18 | |
17 |
pack | 91772A082 | 18-8 Stainless Steel Pan Head Phillips Machine Screw, 2-56 Thread, 5/8" Length, packs of 100
| Monday morning | 4.15 pack | 4.15 | |
18 |
pack | 90402A146 | Zinc-Plated Steel Pan Head Phillips Machine Screw, External Washer, 6-32 Thread, 3/8" Length, packs of 100
| Monday morning | 6.95 pack | 6.95 | |
19 |
pack | 92000A118 | 18-8 Stainless Steel Metric Pan Head Phillips Machine Screw, M3 Size, 8mm Length, .5mm Pitch, packs of 100
| Monday morning | 4.66 pack | 4.66 | |
20 |
pack | 92000A120 | 18-8 Stainless Steel Metric Pan Head Phillips Machine Screw, M3 Size, 10mm Length, .5mm Pitch, packs of 100
| Monday morning | 4.34 pack | 4.34 | |
21 |
pack | 97334A992 | Nylon Socket Head Cap Screw, 10-32 Thread, 1" Length, Black, packs of 100
| Monday morning | 6.41 pack | 6.41 | |
22 |
pack | 91290A130 | Black Class 12.9 Socket Head Cap Screw, Alloy Steel, M3 Thread, 30mm Length, 0.50mm Pitch, packs of 100
| Monday morning | 14.41 pack | 14.41 | |
23 |
2 packs | 91290A224 | Black Class 12.9 Socket Head Cap Screw, Alloy Steel, M5 Thread, 10mm Length, 0.80mm Pitch, packs of 100
| Monday morning | 9.41 pack | 18.82 | |
24 |
pack | 91290A228 | Black Class 12.9 Socket Head Cap Screw, Alloy Steel, M5 Thread, 12mm Length, 0.80mm Pitch, packs of 100
| Monday morning | 10.81 pack | 10.81 | |
25 |
pack | 91290A230 | Black Class 12.9 Socket Head Cap Screw, Alloy Steel, M5 Thread, 14mm Length, 0.80mm Pitch, packs of 100
| Monday morning | 11.52 pack | 11.52 | |
26 |
pack | 91290A252 | Black Class 12.9 Socket Head Cap Screw, Alloy Steel, M5 Thread, 25mm Length, 0.80mm Pitch, packs of 50
| Monday morning | 7.24 pack | 7.24 | |
27 |
pack | 91290A254 | Black Class 12.9 Socket Head Cap Screw, Alloy Steel, M5 Thread, 30mm Length, 0.80mm Pitch, packs of 50
| Monday morning | 7.87 pack | 7.87 | |
28 |
pack | 91290A256 | Black Class 12.9 Socket Head Cap Screw, Alloy Steel, M5 Thread, 35mm Length, 0.80mm Pitch, packs of 50
| Monday morning | 9.67 pack | 9.67 | |
29 |
pack | 91290A260 | Black Class 12.9 Socket Head Cap Screw, Alloy Steel, M5 Thread, 45mm Length, 0.80mm Pitch, packs of 50
| Monday morning | 11.24 pack | 11.24 | |
30 |
pack | 92146A005 | 18-8 Stainless Steel Split Lock Washer, Number 4 Screw Size, .21" OD, .02" min Thick, packs of 1000
| Monday morning | 5.22 pack | 5.22 | |
31 |
pack | 92146A011 | 18-8 Stainless Steel Split Lock Washer, Number 10 Screw Size, .34" OD, .04" min Thick, packs of 1000
| Monday morning | 11.14 pack | 11.14 | |
32 |
pack | 94785A411 | 18-8 Stainless Steel Square Nut, 10-32 Thread Size, 3/8" Width, 1/8" Height, packs of 100
| Monday morning | 8.73 pack | 8.73 | |
33 |
pack | 94639A208 | Nylon Unthreaded Spacer, 1/4" OD, 7/8" Length, #4 Screw Size, packs of 100
| Monday morning | 9.35 pack | 9.35 | |
34 |
pack | 94639A350 | Nylon Unthreaded Spacer, 5/16" OD, 1/8" Length, #10 Screw Size, packs of 100
| Monday morning | 7.04 pack | 7.04 | |
35 |
pack | 94639A352 | Nylon Unthreaded Spacer, 5/16" OD, 1/4" Length, #10 Screw Size, packs of 100
| Monday morning | 7.45 pack | 7.45 | |
36 |
pack | 94639A454 | Nylon Unthreaded Spacer, 3/8" OD, 3/8" Length, #10 Screw Size, packs of 100
| Monday morning | 8.05 pack | 8.05 | |
37 |
pack | 94639A450 | Nylon Unthreaded Spacer, 3/8" OD, 7/8" Length, #10 Screw Size, packs of 100
| Monday morning | 9.64 pack | 9.64 | |
38 |
pack | 91770A096 | 18-8 Stainless Steel Truss Head Phillips Machine Screw, 4-40 Thread, 1/2" Length, packs of 100
| Monday morning | 4.70 pack | 4.70 | |
39 |
pack | 91770A144 |
18-8 Stainless Steel Truss Head Phillips Machine Screw, 6-32 Thread, 1/4" Length, packs of 100
| Monday morning | 4.35 pack |
