A few days ago i ordered parts for part of the frame from misumi, they have a special going on where I could get $150 off the first order.
The details of the discount are here, I accidentally used First150--Reddit, but that is not the right code, since they have it for a specific set of parts for a 3d Printer.
"To receive the $150.00 Credit, companies must place their first order online using a Credit Card and include promotion code "First150--BuildLog" in the "Special Instructions" of the order. Offer is based only on the value of the goods purchased; freight and handling charges are excluded. The full value of the $150.00 credit must be used on the first order, no promotional credit balance will carried forward. Offer expires March 31, 2014. Available in US and Canada only."
Details are here.
http://www.buildlog.net/forum/viewtopic.php?f=2&t=2445&p=21864
Sorry about the funky layout, i copied it off the order I made, you should double check with the Buildlog BOM, because if i did make any mistakes i won't know til i start assembling it.
Line Item
Name
Part number
Description
Quantity
Item Cost
Total Cost
1
CAST CORNER BRACKET
HBLFSN5
Assembly Brackets Slot Width 6
45
0.75
33.75
2
THIN BRACKET, 1 WIDE
HBLSS5
2
1.02
2.04
3
THIN CORNER BRACKET
HBLTS5
2
1.10
2.20
4
EXTRUSION 2020 160MM LG.
HFS5-2020-160
ALUMINUM FRAME
1
3.03
3.03
5
EXTRUSION 2020 230MM LG.
HFS5-2020-230
ALUMINUM FRAME
1
3.03
3.03
6
EXTRUSION 2020 310MM LG.
HFS5-2020-310
ALUMINUM FRAME
4
1.76
7.04
7
EXTRUSION 2020 370MM LG.
HFS5-2020-370
ALUMINUM FRAME
2
2.10
4.20
8
EXTRUSION 2020 440MM LG.
HFS5-2020-440
ALUMINUM FRAME
2
2.50
5.00
9
EXTRUSION 2020 560MM LG.
HFS5-2020-560
ALUMINUM FRAME
7
3.19
22.33
10
EXTRUSION 2020 580MM LG.
HFS5-2020-580
ALUMINUM FRAME
2
3.30
6.60
11
EXTRUSION 2020 725MM LG.
HFS5-2020-725
ALUMINUM FRAME
2
4.13
8.26
12
EXTRUSION 2020 728MM LG.
HFS5-2020-728
ALUMINUM FRAME
1
4.14
4.14
13
EXTRUSION 2020 730MM LG.
HFS5-2020-730
ALUMINUM FRAME
3
4.16
12.48
14
EXTRUSION 2020 90MM LG.
HFS5-2020-90
ALUMINUM FRAME
1
3.03
3.03
15
EXTRUSION 2020 960MM LG.
HFS5-2020-960
ALUMINUM FRAME
3
5.47
16.41
16
EXTRUSION 2040 960MM LG.
HFS5-2040-960
ALUMINUM FRAME
2
10.36
20.72
17
HINGE - LEFT
SHHPSL5-2
Detachable Hinges
1
7.31
7.31
18
HINGE - RIGHT
SHHPSR5-2
STAINLESS SLIP JOINT HINGES
1
7.31
7.31
03/03/2014
19
M5 T-SLOT NUT
HNKK5-5
NUTS FOR ALUMINIUM FRAMES
1
19.32
19.32
20
POST ASSEMBLY NUT
HNTP5-5
NUTS FOR ALUMINUM FRAME
10
0.58
5.80
