Additional Relay
01/04/2018 at 06:42 • 0 comments- The IR controlled outlet can also be customized by adding more relays
![a1.png]()
- The command codes for each relay can also be customized through the following lines of code
![a2.png]()
- The additional relays can be added to the circuit for the IR controlled circuit
![Receiver Ckt.png]()
4D Makers
