A rebuild
01/21/2018 at 19:51 • 0 commentsVery nice, there's another Tiny POV. It's a build from
Sourcecode
01/11/2018 at 17:26 • 0 commentsI have added the link to the source code to the project description (https://github.com/jensh/attiny-tiny-pov). If you are happy with "Hello", you can flash pov.hex:
avrdude -v -p attiny13 -cusbasp -Uflash:w:pov.hex:i -
Synchronization
01/10/2018 at 09:37 • 0 commentsI have attached a "ball tilt sensor" to the reset line (pin 1). Unfortunately the sensor is larger than the display itself. Here is the video. Still not impressive compared to what it looks like in real life. But it's getting better.
Jens Hauke
