Building a robot is no easy task. Robot vacuums have most of the hard work already done and are becoming easier to get for free or a bargain price. This project documents my experience in getting a UTMARK X500 to be controlled via a netbook running python. This should provide an excellent environment for experimenting with localisation, path planning and SLAM type algorithms.
This type of thing has been done before so I will try and use as much existing knowledge as I can. I also wish to spend as little as possible on the project and salvage as much as possible.
Components
1×
UTMARK X500
A robot vacuum kindly donated to me by my PhD supervisor
1×
Sony VAIO PCG-TR3 Netbook
Thanks to JLord for this one!
Opened up the robot vacuum to try and get a good look at what is inside and how best to make it do my bidding (I will try and put up some photos later). I am pretty new to hardware hacking but even I know the first step in any hardware hack is to identify the chips on the board.
I am happy to report that the UTMARK X500 uses an STM32 ARM based microcontroller. The STM32F103VB to be specific. This is good news as there is a huge amount of documentation for this microcontroller series on the ST website. It also has a huge number of build in communication protocols including USART,USB,I2C and CAN. Chances are I will be able to use one of these to communicate with the netbook.
Perhaps the most interesting thing about this microcontroller series is that it ships with a bootloader build into ROM. By setting the correct logic levels on the BOOT0 and BOOT1 pins, it is possible to load this bootloader which is able to communicate over any of those protocols listed above and perform useful tasks like reprogram the flash or reconfigure the pins. The bootloader reference also states that it is possible to dump the current contents of the flash although I assume there is some sort of security build in.
In summary I have decided the next step is to try and communicate with this bootloader. I will try and break out the requisite pins from the main board and hopefully be able to connect a USB to USART and get communicating. Wish me luck.
Obviously, making robotic vacuum cleaner is the piece of cake in today's world. I remember the very first day when i started making a copy of deebot (My gradpas vacuum) . https://vactrends.com/deebot-m80-review/
I have gone through many sites but https://vactrends.com/best-vacuums-for-pet-hair/
this site help me alot
