Wanted kiln capable of fusing 3ft x 6ft glass art. Kiln has top and bottom elements with a suspended hearth of silicon carbide tiles and fiber insulation. Quartz windows. Computer controlled heating programs and venting.
Components
80×
Ceramic Fiber Insulation Modules
1" thick ceramic fibers oriented perpendicular wall plane. Compressed onto a stainless steel mandrel and banded at 300 PSI. Tightly installed, the bands can be cut while still keeping the insulation under compression. Installation is "finished" off by hammering their kiln-side surfaces with a 2x4 and then spraying them with silica rigidizer to prevent dust. Temperature rated to 2300F.
40×
Mullite Tubing - 1" x 40"
These support the Kanthal heating elements. They are almost as strong and heat resistant as alumina, at a fraction of the cost.
4×
Insulation Board
This was used as a support for the lower element tubes below the hearth. It is not suitable as wall insulation.
8×
Silicon Carbide Hearth Tiles
18" x 18" Recrystallized silicon carbide forms the hearth tiles in 2 rows of 4. It is strong, flat, dora not warp and transmits hear relatively well for a refractory. It is also less susceptable to thermal breakage.
5×
Silicon Carbide Beams
The hearth tiles sit on a series of 2"x2"x2' silicon carbide beams which run the width of the kiln.
I haven't built one, but you might try a fiber lined cylinder containing a spiral heating element wound around the inner circumference. It might provide very even heating. Place the work to be heated on the midline.
The kiln just sort of happened. We had a 17" Evenheat and wanted something larger. I had a background in studio ceramics and we were thinking in terms of brick "bath tub" kilns. By chance, we encountered a Skutt GM22CS, a sweet 24" kiln whose design I still admire. It was too expensive at the time, but it introduced us to totally new ways of thinking. I also spent a summer at Pilchuck and got to see large professional kilns by BVD and Nabertherm and others. A mutual friend introduced me to a great NASA thermal engineer about that time and I began to seriously study kiln design and heat. My most useful discovery was: "Make friends with sales engineers - they know a lot". As we realized that we could build a really nice kiln, my wife and I talked ourselves into larger and larger designs, with the available power coming into our studio finally setting a firm upper limit. The design evolved over several years as we collected components and finally being laid off in 2007 provided me with 6 months of free time to work on actual construction. I started in ernest in August and we saw "first heat" just after New Years. It lasted about 5 minutes and then a 100A breaker blew, but it was still a thrill.
Hi Adam, I have actually thought about this - fusing 12"-14" mirror blanks, but the viewing is too poor in LA where I live and there is already a cottage industry of people casting mirrors, so I decided not to work on it as a personal project. (Or you really considering a refractor lens?) Either way, the biggest issue is the annealing time for thick glass, even if it is honeycombed. Micro-bubbles and unwanted inclusions are a secondary issue. Pyrex (2150F) also wears out the kiln faster. We have a smaller kiln which might still be good for a 12"-14" window glass blank and not compete with our other projects for available power. (The big kiln maxes out our 100A feed.) Aside from raw power, optical glass requires very slow annealing - probably at least 5 days/inch thickness (4F/hr). I anneal think art pieces about 5 times faster and it is still a slow process. I'm not sure that I could beat anyone on the cost of Pyrex, however, unless I fused 8 mirrors at a time and had orders for them. How big a mirror are you thinking of? My astronomy friends tell me that past 12", one needs active optics to correct for atmospheric distortion and realize the full benefit of such a large mirror. I've actually seen some pretty nice deep space photos from 4" refractors equipped with star trackers, precision mounts, and low noise CCD's - probably $10,000 worth of equipment.
I don't have time just now to look for projects, but here is an ArtSlant link which shows some.
http://www.artslant.com/global/artists/show/176941-bruce-hubbard?tab=ARTWORKS
Bruce,
Thank you for posting this on the HAD.io website.
I have an L&L kiln that I'm satisfied with but want to build a smaller kiln for copper enameling and your design has some elements I'll use for that.
Adam, here is a link to Bruce's website that also explains why they are so busy:
http://www.directimagination.com/aboutus.html
