1Step 1
Here is a rough overview of what i did to get it al working, some steps are more detailed than others, i will try to share as much as i can.
1. Download the porta pi image (google it), this is a pre-configured pack of retropie and emulationstation and has a bunch of emulators installed.
2. Mount it on a SD card using Win32 Disk Imager.
3. Edit the GPIO mapping (See step 2).
4. Place your roms on a USB stick and transfer them to your Raspberry Pi and place them in the correct folders inside /home/pi/RetroPie/roms (for examle, place your GBA games inside /home/pi/RetroPie/roms/GBA).
5. For the GBA emulator to work you need to download a BIOS and place it on your pi, see step 3 for detailed instructions.
6. Getting the startup splash screen to work (see step 4).
2Step 2
Edit GPIO mapping :
1. Open retrogame config file :
CD /home/pi/Retrogame sudo nano retrogame.c
2. Scroll down until you see the input array.
3. For a 1-player arcade machine you need to remove the player 2 inputs for it to work.
4. Edit the GPIO pin numbers for player 1 arcording to your wiring.
5. Press CTRL + O to save your changes
6. Press CTRL + X to exit the editor
7. Make the file and reboot :
make sudo reboot
3Step 3
Getting the GBA emulator to work :
1. Download gba_bios.bin.
2. Transfer gba_bios.bin to /home/pi/retropie/BIOS from a USB stick.
3. Reboot your pi :
sudo reboot
4. Move the file to it's destination folder :
cd /home/pi/RetroPie/BIOS sudo cp gba_bios.bin /opt/retropie/emulators/gpsp/raspberrypi
5. Start emulationstation :
emulationstation
6. Configuring input controls for the GBA emulator :
Open any game.
Press F10 while in the game.
Choose the 'input keyboard' option.
Here you can change your keyboard inputs.
4Step 4
Installing a splash screen that you will see at startup instead of a list of commands.
This kindof works, but only for the last part of the loading proces, i haven't found a better way yet but this is better than nothing.
First of all, you need to install fbi:
apt-get install fbi
Copy your custom splash image to /etc/ and name it "splash.png".If if file called 'asplashscreen' does not exsist; create a new file called 'asplashscreen' in /etc/init.d/Open the 'asplashscreen' file :
CD /etc/init.d/ sudo nano asplashscreen
Place the following code into the the file: 'asplashscreen' :#! /bin/sh ### BEGIN INIT INFO # Provides: asplashscreen # Required-Start: # Required-Stop: # Should-Start: # Default-Start: S # Default-Stop: # Short-Description: Show custom splashscreen # Description: Show custom splashscreen ### END INIT INFO do_start () { /usr/bin/fbi -T 1 -noverbose -a /etc/splash.png exit 0 } case "$1" in start|"") do_start ;; restart|reload|force-reload) echo "Error: argument '$1' not supported" >&2 exit 3 ;; stop) # No-op ;; status) exit 0 ;; *) echo "Usage: asplashscreen [start|stop]" >&2 exit 3 ;; esac :
Then make that script executable and install it for init mode rcS:
sudo chmod a+x /etc/init.d/asplashscreen sudo insserv /etc/init.d/asplashscreen Reboot and watch your custom splash screen: sudo reboot
