1Step 1
First I made a plan which parts I might want to build this. Selected a suitable mother board for the project.
2Step 2
Designed a aluminum enclosure for best size.
3Step 3
Fixed touch sensitive panel for 7" monitor
4Step 4
Installed 12V to ATX power converter module for Motherboard ATX power socket. other power outputs fitted with Hard drive.
5Step 5
Finished the physical installation part. and finally installed windows 7 OS using portable hard disk.
6Step 6
Tested OBD software with OBD usb module
