First Tests and next Iteration
10/29/2014 at 08:58 • 1 commentWell, after some short tests and now a little longer test last night i can put out some resume:
+ The Flashlight is bright and illuminates pretty good for example when doing something at night on the balcony etc.
+/- the Battery holds up around 1 hour i would say. 240mAH 9V Rechargable.
- The LEDs get hot, i knew that, but didn't expect them to melt the hotglue again, even with open lidSo for the next iteration i will:
- Use bright white LEDs not the warm white ones
- i will somehow bolt the LEDs that the don't get loose because of the heat
- Constant Current instead of constant Voltage.
- And for that i might have to use 2x9V Blocks.....
- i would like to add a charging mechanism, so that i can recharge the battery while it is plugged in.
- Maybe i add a fan.... but that i would like to stay fanless....Maybe i need a bigger enclosure....
Video
09/21/2014 at 18:45 • 0 comments -
For the next time
09/21/2014 at 15:06 • 1 commentWhen i would do this again, i would certainly clean and paint the mint box first.
Also there is no room for a cooling Fan, which i would like to add as well. For this, the Battery would have to go.
Sango
