We needed a great build workshop for Hackaday's 10th anniversary, and shlonkin's tiny robots were a perfect fit. These robots are low cost, easy to source parts for, and perform really well. We did change things a bit. The major change was going to through hole components rathern than the original surface mount parts. This keeps the design within the skill level of even a beginner solder slinger.
Start with a piece of perf board 8 holes wide by 11 holes tall. We used used Plated through holes for prototyping, but this layout will work with PTH or single layer boards. Be careful cutting and/or sanding the board - fiberglass dust is nasty stuff. To minimize dust, We suggest using a pair of tin snips to cut the board, or the tried and true "score with a knew and snap" method.
2
Step 2
Solder in an 8 pin socket for your ATtiny85. Leave two holes free below the socket and two on each side.
3
Step 3
Solder in the 0.1uf bypass cap just above the upper right pin of the ATtiny.
Bend the leg of the capacitor down and solder it to pin 8 (VCC) of the ATtiny. The other capacitor leg can be soldered in straight.
