Hackaday.io Hackaday.io
Sign up Log in
DIY silent air compressor
A couple of videos where I explain how to turn a compressor from a fridge into a silent air compressor.
kerimilkerimil
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
6.3k views
2 comments
96 followers
  • Description
  • Details
  • Files 0
  • Components 3
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 2
View Gallery
6.3k
2
96
13
Team (1)
  • kerimilkerimil
Join this project's team
  • Video playlist - how to modify a fridge compressor
fridge compressor silent air compressor pneumatics vacuum pump pressure air compressor compressor
This project was created on 03/07/2014 and last updated 12 years ago.
Description
A series of videos where I describe how to modify a fridge compressor into a silent air compressor. I discuss the overall process, how to remove it from an old fridge, wiring, a simple homemade compression fitting and how to test the motor windings and PTC relays. If you have any questions or comments feel free to post them. I'll be adding a video on how to use them as vacuum pumps soon
Details
Components
  • 1 × fridge compressor either remove one from a fridge or buy as a replacement part
  • 1 × on/off switch simply put it in place of the thermostat
  • 1 × a fitting to attach to the outlet tube I prefer to use compression fittings for convenience, but you might as well use brazing or just clamp on flexible tubing over the tube
Log In/Sign up to comment
Sign up with Github
OR
kerimil wrote 04/07/2014 at 23:20 • point
10 litre tank to 400 psi in about 10 minutes. Overall it's flow is rather low, but it can reach much higher pressures than normal shop compressors (500 psi and more)
phil wrote 03/24/2014 at 20:04 • point
I have been looking into doing this to my compressor, although brand new the direct drive is far too noisy to use, would this be able to fill a large tank within a reasonable time?
Convert a Stahl 40W solder station into a hot air solder pencil. Fully reversible to a tipped iron for dual action. Fingertip air throttle!
Project Owner Contributor
DIY Hot Air Solder Pencil Iron
mosaicmercmosaicmerc
The 2016 Hackaday Prize
15% of the population or 21 million in the US could save $100 a year
Thomas Atmospheric Dryer
david-thomasDavid Thomas
The 2015 Hackaday Prize
A household air purification unit for kitchens, labs, & smokers used to scrub fine particulates and VOC's out of the air.
Household Electrically Enhanced Wet Scrubber
jimmy-lockeJimmy Locke
Fresh Air Exhaust with coffee powder or cinnamon...
Electronic Air Freshener
eduardo-zolaEduardo Zola
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "DIY silent air compressor", please tell us the reason.
Send message
Remove Member
