1Step 1
Build this circuit: power + pulse + light wire + light wire. Adjust the pulse to whatever speed you like.
2Step 2
Use the hook & loop bitsnaps to secure your circuit so they dont separate. Use the adhesive hook & loop strip to adhere it to your material.
3Step 3
Bend the lightwire into the shape of a stick figure. The lightwire is great because it holds the general shape once you bend it.
4Step 4
Use a needle and thread to sew the lightwire into your clothing. We recommend light thread and dark fabric.
5Step 5
Go forth and be spooky!
littleBits
