1Step 1
Assemble the circuit: power + wire + motion trigger + servo. Make sure the servo is set to "turn" mode. Test the circuit. You will need to be very still so as to not activate the motion trigger. Then, when you move, the servo should turn.
2Step 2
Next you will need a frame and portrait to hack. We suggest you use a frame that is deep enough to embed the servo (~1.5"). We used an 11" x 14" x 1.5" wood frame from Blick. You can use a portrait from your house or you can print out version we used. If you are not using our version, you will also need to make two sets of eyes to will sit behind the portrait (one normal set and one scary set). The two sets of eyes should be spaced ⅞" from center to center.
3Step 3
Carefully cut the eyes out from the main portrait. Then tape the photo (image facing out) to the inside of the frame.
4Step 4
Use the back panel of the frame as a mount for the circuit and the eye mechanism. With our frame, we are able to secure the back panel in the frame so that there is about an inch of space between the portrait and the panel.
5Step 5
Mount the circuit on the back panel using adhesive shoes. Position the motion trigger in a strategic place corresponding to the photo. We chose a spot in the tie that had lots of texture. Then cut a very small hole in the portrait so the motion trigger can see through it. Test the circuit with the portrait over it and make sure the motion trigger sees your movement.
6Step 6
While everything is lined up, with a pencil, mark where the normal set of eyes should eventually sit on the back panel through the eye cutouts.
7Step 7
Cut the eyes file to be 3.5" wide by ~2" tall. Mount the image onto a piece of ¼" foamcore cut to 3.5" wide by ~4" tall. Tape or glue the eyes to the foamcore. They should be positioned at the bottom.
8Step 8
Place the foamcore eyes directly over the markings you just made on the back panel. Trace the foamcore rectangle and make sure the lines extend a few inches beyond in each direction.
9Step 9
Cut three layers of ¼" foamcore to sit underneath the eyes so that they sit closer to the portrait and at a similar height to the servo arm. The dimensions of our layers are 4.5" wide x 5" tall. Glue the three layers together.
10Step 10
Using a hobby saw, cut two 5" pieces from a ½" dowel. Glue the two dowels along the edges on top of foamcore platform you just created. Place the eyes in the center and make sure they move up and down smoothly. Then glue the whole platform to the back panel, making sure to keep the eyes lined up with where they correspond with the portrait.
littleBits
