After a hickup associated with Windows 10 Technical Preview BSODing my laptop, and my Virtual Box not seeming to accept any USB devices, allthree SD cards are running Retro-pi 3 for Raspberry pi 2, each with the ROMS installed.
Following the previous, non-existing project log (finally figuring out how to use these things), debugging of the Nintendo 64 controller will be used to ensure none of the wires broke when attaching the PCB to the back of the screen.
A couple of the heatsyncs for the RPI's came in. I noticed that the SOC's were getting fairly hot when playing games such as LOZ Majora's Mask. Still don't have any plans on how to remove the heat outside of the container, once removed from the chip.
