So I am bad at project logs. It's on my todo list to get better at those.
Anyhow, the project was complete using the new components list. Pictures will be loaded.
Things I discovered over the past few weeks:
It appears that the RPI 2 can be powered over standard USB from a computer, but there are erroneous things that occur in that case. Specially video quality and audio quality drops significantly in that case. Providing a supply that can supply up to 1A is sufficient to remove the sheath current associated with the limited supply, which allows the Audio and Video quality to improve dramatically.
MDF does not like to be screwed together and is easily breakable, so it turns out a lot of my cuts using the circular saw were not quite as accurate as I hoped. For this reason, there was a lot of additional wood glue used in the gaps to ensure it holds together solidly.
This is more apparent in the pictures, but a slot was made for the battery to hold inside of the *cabinet*, but can be removed if desired or if it needs to be charged. The middle compartment houses the RPI 2. Holes were cut in the MDF to expose the HDMI/Power/Aux/USB/Ethernet ports to allow access to use it as a computer if more games are desired or whatever may be. The top portion shows the screen, just held in place by the 3M adhesive bottom and the wooden enclosure.
