1Step 1
1.) I first decoded a random remote that the Beacon had in its list of devices. Those recorded values is what is used to tell the Attiny what code to send
2Step 2
2.) Cut Positive and negative lines from battery compartment
3Step 3
3.) Remove battery terminals-----------------------------------------------------------------------------------------
4Step 4
4.) Solder three wires to TSOP and enclose any exposed contacts
5Step 5
5.) Solder positive wire to V+ and negative wire to GND on Beacon
6Step 6
6.) Slide TSOP under the first board to avoid mounting screw holes
7Step 7
7.) Snake the Data wire of TSOP through the hole that the power and ground wires go. Screw the bottom and cover back together.
8Step 8
8.) The RF TX module i bought had a 90 degree pin header so I needed to resolder a straight header
9Step 9
9.) Drill one hole for the USB power chord in the rear of the device and one hole in the front center for the indicator LED
10Step 10
10.) Solder DIP socket, RF module, resistors and use wires as placements to connect the data line of the IR Receiver and LED
joedefa
