Solves Sudoku puzzles (work in progress)
D3, D4, D5, D13 are used by the LCD.
D6..D9 are keyboard rows.
A0..A3 are keyboard columns. I intentionally map these backward so the physical wiring would be pretty. :-)
WARNING: Note that the LCD is 3.3V!!!
Using a multimeter, I deduced the rows and columns matrix of the keypad.
Incidentally, there is as much as 2K resistance on they keypress, so I could not use the beeper on the multimeter.
Oops sorry, I must've moved the code in GitHub. I've updated the broken link, but here it is again. Thanks for letting me know.
https://github.com/hwiguna/g33k/tree/master/ArduinoProjects/2014/LCD/Nokia5110_Sudoku01
please give your pin map
