Use the TivaWare peripheral library to get PWM working on the Tiva C launchpad: http://www.ti.com/tool/sw-tm4c
I made an example of dimming LEDs that can be complied with GCC: https://github.com/szczys/tiva-c-launchpad-hardware-pwm/blob/master/main.c
Specific code for servo timing is found below. The datasheet for the TM4C123GH6PM includes this table which can be used to find out the PWM module, generator, pin, and other values:
# Hardware PWM proof of concept using
# the Tiva C Launchpad
# Started with example code by
# lawrence_jeff found here:
# http://forum.stellarisiti.com/topic/707-using-hardware-pwm-on-tiva-launchpad/
# Altered to use code found on section
# 22.3 of the TivaWare Peripheral Driver
# Library User's Guide found here:
# http://www.ti.com/lit/ug/spmu298a/spmu298a.pdf
# This example drives servo motors on PF1, PF2, and PF3
#include "driverlib/pin_map.h"
#include <stdint.h>
#include <stdbool.h>
#include "inc/hw_gpio.h"
#include "inc/hw_types.h"
#include "inc/hw_memmap.h"
#include "driverlib/sysctl.h"
#include "driverlib/gpio.h"
#include "driverlib/pwm.h"
void delayMS(int ms) {
SysCtlDelay( (SysCtlClockGet()/(3*1000))*ms ) ;
int
main(void)
uint32_t period = 5000; //20ms (16Mhz / 64pwm_divider / 50)
uint32_t duty = 250; //1.5ms pulse width
//Set the clock
SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN | SYSCTL_XTAL_16MHZ);
//Configure PWM Clock divide system clock by 64
SysCtlPWMClockSet(SYSCTL_PWMDIV_64);
// Enable the peripherals used by this program.
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
SysCtlPeripheralEnable(SYSCTL_PERIPH_PWM1); //The Tiva Launchpad has two modules (0 and 1). Module 1 covers the LED pins
//Configure PF1,PF2,PF3 Pins as PWM
GPIOPinConfigure(GPIO_PF1_M1PWM5);
GPIOPinConfigure(GPIO_PF2_M1PWM6);
GPIOPinConfigure(GPIO_PF3_M1PWM7);
GPIOPinTypePWM(GPIO_PORTF_BASE, GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_3);
//Configure PWM Options
//PWM_GEN_2 Covers M1PWM4 and M1PWM5
//PWM_GEN_3 Covers M1PWM6 and M1PWM7
PWMGenConfigure(PWM1_BASE, PWM_GEN_2, PWM_GEN_MODE_DOWN | PWM_GEN_MODE_NO_SYNC);
PWMGenConfigure(PWM1_BASE, PWM_GEN_3, PWM_GEN_MODE_DOWN | PWM_GEN_MODE_NO_SYNC);
//Set the Period (expressed in clock ticks)
PWMGenPeriodSet(PWM1_BASE, PWM_GEN_2, period);
PWMGenPeriodSet(PWM1_BASE, PWM_GEN_3, period);
//Set PWM duty
PWMPulseWidthSet(PWM1_BASE, PWM_OUT_5,duty);
PWMPulseWidthSet(PWM1_BASE, PWM_OUT_6,duty);
PWMPulseWidthSet(PWM1_BASE, PWM_OUT_7,duty);
// Enable the PWM generator
PWMGenEnable(PWM1_BASE, PWM_GEN_2);
PWMGenEnable(PWM1_BASE, PWM_GEN_3);
// Turn on the Output pins
PWMOutputState(PWM1_BASE, PWM_OUT_5_BIT | PWM_OUT_6_BIT | PWM_OUT_7_BIT, true);
while(1)
delayMS(2000);
//Drive servo to 135 degrees
PWMPulseWidthSet(PWM1_BASE, PWM_OUT_5,duty+(duty/2));
PWMPulseWidthSet(PWM1_BASE, PWM_OUT_6,duty+(duty/2));
PWMPulseWidthSet(PWM1_BASE, PWM_OUT_7,duty+(duty/2));
delayMS(2000);
//Drive servo to 90 degrees
Mike Szczys
how did you calculate period and duty cycle..........what is the system clock frequency that you set???
