Atmel SAMD20 Xplained Pro
A project log for PWM examples with multiple architectures
This is the cheat sheet for the Embedded Hardware Workshop
mike-szczysMike Szczys • 11/08/2014 at 03:53•0 Comments
This one's a bit of a kludge but it does work. There's a bit of drift (or something) but I didn't have time to scope the output and fix it. Sorry.
This uses the GCC example for "delay" in the Atmel Software Framework:
http://www.atmel.com/tools/avrsoftwareframework.aspx?tab=overview
There are 3 files you need to edit:
common2/services/delay/example/
 * \file
 * \mainpage
 * \section title Delay service example
 * \section file File(s)
 * - \ref delay_example.c
 * Copyright (c) 2011 - 2014 Atmel Corporation. All rights reserved.
 * \asf_license_start
 * \page License
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions are met:
 * 1. Redistributions of source code must retain the above copyright notice,
 *    this list of conditions and the following disclaimer.
 * 2. Redistributions in binary form must reproduce the above copyright notice,
 *    this list of conditions and the following disclaimer in the documentation
 *    and/or other materials provided with the distribution.
 * 3. The name of Atmel may not be used to endorse or promote products derived
 *    from this software without specific prior written permission.
 * 4. This software may only be redistributed and used in connection with an
 *    Atmel microcontroller product.
 * THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR IMPLIED
 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
 * MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE
 * EXPRESSLY AND SPECIFICALLY DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR
 * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
 * STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
 * ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
 * POSSIBILITY OF SUCH DAMAGE.
 * \asf_license_stop
#include <asf.h>
#define PWM_MODULE EXT1_PWM_MODULE
#define PWM_OUT_PIN EXT1_PWM_0_PIN //PB02
#define PWM_OUT_MUX EXT1_PWM_0_MUX
struct tc_module tc_instance;
void configure_tc(void)
     struct tc_config config_tc;
     tc_get_config_defaults(&config_tc);
     config_tc.counter_size = TC_COUNTER_SIZE_16BIT;
     config_tc.wave_generation = TC_WAVE_GENERATION_NORMAL_PWM;
     //config_tc.counter_16_bit.compare_capture_channel[0] = (0xFFFF / 2);
     config_tc.counter_32_bit.compare_capture_channel[0] = (8000);
     config_tc.pwm_channel[0].enabled = true;
     config_tc.pwm_channel[0].pin_out = PWM_OUT_PIN;
     config_tc.pwm_channel[0].pin_mux = PWM_OUT_MUX;
     tc_init(&tc_instance, PWM_MODULE, &config_tc);
     tc_set_top_value(&tc_instance,160000);
     tc_enable(&tc_instance);
void setDuty(uint32_t duty) {
    tc_set_compare_value(&tc_instance, TC_COMPARE_CAPTURE_CHANNEL_0, duty);
    //Do we need to reset the counter? What if we already passed top?
int main(void)
	system_init();
	delay_init();
    configure_tc();
	struct port_config pin;
	port_get_config_defaults(&pin);
	pin.direction = PORT_PIN_DIR_OUTPUT;
	port_pin_set_config(LED0_PIN, &pin);
	port_pin_set_output_level(LED0_PIN, LED0_INACTIVE);
	while (true) {
        delay_s(2);
        setDuty(16000);
        delay_s(2);
        setDuty(12000);
        delay_s(2);
        setDuty(8000);
common2/services/delay/example/samd20_xplained_pro/gcc/asf.h
Just add this before the last #endif:
#include <tc.h>
common2/services/delay/example/samd20_xplained_pro/gcc/config.mk
To this file we're just adding the includes for tc.c and the tc path but I'll paste the entire file:
# Copyright (c) 2011 Atmel Corporation. All rights reserved.
# \asf_license_start
# \page License
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions are met:
# 1. Redistributions of source code must retain the above copyright notice,
#    this list of conditions and the following disclaimer.
# 2. Redistributions in binary form must reproduce the above copyright notice,
#    this list of conditions and the following disclaimer in the documentation
#    and/or other materials provided with the distribution.
# 3. The name of Atmel may not be used to endorse or promote products derived
#    from this software without specific prior written permission.
# 4. This software may only be redistributed and used in connection with an
#    Atmel microcontroller product.
# THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR IMPLIED
# WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
# MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE
# EXPRESSLY AND SPECIFICALLY DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR
# ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
# DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
# OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
# HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
# STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
# ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
# POSSIBILITY OF SUCH DAMAGE.
# \asf_license_stop
# Path to top level ASF directory relative to this project directory.
PRJ_PATH = ../../../../../..
# Target CPU architecture: cortex-m3, cortex-m4
ARCH = cortex-m0plus
# Target part: none, sam3n4 or sam4l4aa
PART = samd20j18
# Application target name. Given with suffix .a for library and .elf for a
# standalone application.
TARGET_FLASH = delay_example_flash.elf
TARGET_SRAM = delay_example_sram.elf
# List of C source files.
CSRCS = \
       common/utils/interrupt/interrupt_sam_nvic.c        \
       common2/services/delay/example/delay_example.c     \
       common2/services/delay/sam0/systick_counter.c      \
       sam0/boards/samd20_xplained_pro/board_init.c       \
       sam0/drivers/port/port.c                           \
       sam0/drivers/system/clock/clock_samd20/clock.c     \
       sam0/drivers/system/clock/clock_samd20/gclk.c      \
       sam0/drivers/system/interrupt/system_interrupt.c   \
       sam0/drivers/system/pinmux/pinmux.c                \
       sam0/drivers/system/system.c                       \
       sam0/drivers/tc/tc.c                               \
       sam0/utils/cmsis/samd20/source/gcc/startup_samd20.c \
       sam0/utils/cmsis/samd20/source/system_samd20.c     \
       sam0/utils/syscalls/gcc/syscalls.c
# List of assembler source files.
ASSRCS =
# List of include paths.
INC_PATH = \
       common/boards                                      \
       common/utils                                       \
       common2/services/delay                             \
       common2/services/delay/example/samd20_xplained_pro \
       common2/services/delay/sam0                        \
       sam0/boards                                        \
       sam0/boards/samd20_xplained_pro                    \
       sam0/drivers/port                                  \
       sam0/drivers/system                                \
       sam0/drivers/system/clock                          \
       sam0/drivers/system/clock/clock_samd20             \
       sam0/drivers/system/interrupt                      \
       sam0/drivers/system/interrupt/system_interrupt_samd20 \
       sam0/drivers/system/pinmux                         \
       sam0/drivers/tc                                    \
       sam0/utils                                         \
       sam0/utils/cmsis/samd20/include                    \
       sam0/utils/cmsis/samd20/source                     \
       sam0/utils/header_files                            \
       sam0/utils/preprocessor                            \
       thirdparty/CMSIS/Include                           \
       thirdparty/CMSIS/Lib/GCC \
# Additional search paths for libraries.
LIB_PATH =  \
# List of libraries to use during linking.
LIBS =  \
       arm_cortexM0l_math
# Path relative to top level directory pointing to a linker script.
LINKER_SCRIPT_FLASH = sam0/utils/linker_scripts/samd20/gcc/samd20j18_flash.ld
LINKER_SCRIPT_SRAM  = sam0/utils/linker_scripts/samd20/gcc/samd20j18_sram.ld
DEBUG_SCRIPT_FLASH = sam0/boards/samd20_xplained_pro/debug_scripts/gcc/samd20_xplained_pro_flash.gdb
DEBUG_SCRIPT_SRAM  = sam0/boards/samd20_xplained_pro/debug_scripts/gcc/samd20_xplained_pro_sram.gdb
# Project type parameter: all, sram or flash
PROJECT_TYPE        = flash
# Additional options for debugging. By default the common Makefile.in will
# add -g3.
DBGFLAGS =
# Application optimization used during compilation and linking:
# -O0, -O1, -O2, -O3 or -Os
OPTIMIZATION = -O1
# Extra flags to use when archiving.
ARFLAGS =
# Extra flags to use when assembling.
ASFLAGS =
# Extra flags to use when compiling.
CFLAGS =
# Extra flags to use when preprocessing.
# Preprocessor symbol definitions
#   To add a definition use the format "-D name[=definition]".
#   To cancel a definition use the format "-U name".
# The most relevant symbols to define for the preprocessor are:
#   BOARD      Target board in use, see boards/board.h for a list.
#   EXT_BOARD  Optional extension board in use, see boards/board.h for a list.
CPPFLAGS = \
       -D ARM_MATH_CM0=true                               \
       -D BOARD=SAMD20_XPLAINED_PRO                       \
       -D SYSTICK_MODE                                    \
       -D __SAMD20J18__
# Extra flags to use when linking
LDFLAGS = \
# Pre- and post-build commands
PREBUILD_CMD =
POSTBUILD_CMD =
type "make" in the GCC directory to build the .elf file. Flash it to the hardware using OpenOCD and arm-none-eabi-gdb as explained here.
Resources:
D20 Timer/Counter Driver
