Reading the US-100 ultrasonic distance sensor is easy:
- Make sure the jumper is not in place
- Power from 3.3V or 5V to match your logic levels
- Pull trigger pin high for 10uS then low
- Watch echo pin to go high, measure time before it goes low. This correlates to distance
It would be better to use a hardware timer but this does work. This code example is for the Tiva C Launchpad board.
# Reading US-100 Ultrasonic Sensor using
# the Tiva C Launchpad
# This example reads from a US-100 ultrasonic sensor
# * Jumper should not be in place
# * VCC to 3.3V
# * GND to GND
# * Trigger to PF2
# * Echo to PF4
# It would be much better to use a hardware time
# instead of incrementing "counter" as I've done here
# The blue LED is on the same pin as trigger so it
# will flash like crazy
# When working correctly the red LED will light up
# when an obstacle is close to the sensor
#include "driverlib/pin_map.h"
#include <stdint.h>
#include <stdbool.h>
#include "inc/hw_gpio.h"
#include "inc/hw_types.h"
#include "inc/hw_memmap.h"
#include "driverlib/sysctl.h"
#include "driverlib/gpio.h"
#include "driverlib/rom.h"
//Max wait time for reading the sensor:
#define MAX_TIME 7500
void delayMS(int ms) {
SysCtlDelay( (SysCtlClockGet()/(3*1000))*ms ) ;
uint32_t measureD(void) {
//Pull trigger high
GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_2, GPIO_PIN_2);
//wait appropriately
SysCtlDelay(SysCtlClockGet()/(3*10)) ; //Delay 10uS
//Pull trigger low
GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_2, 0);
//Monitor echo for rising edge
while (ROM_GPIOPinRead(GPIO_PORTF_BASE, GPIO_PIN_4) == 0) { }
uint32_t counter = 0;
//loop counter checking for falling edge; MAX_TIME make sure we don't miss it
while ((ROM_GPIOPinRead(GPIO_PORTF_BASE, GPIO_PIN_4) != 0) && (counter < MAX_TIME)) { counter++; }
//return value
return counter;
int main(void)
//Set the clock
SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN | SYSCTL_XTAL_16MHZ);
//Enable PortF
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
//LED Pins as outputs
ROM_GPIOPinTypeGPIOOutput(GPIO_PORTF_BASE, GPIO_PIN_1 | GPIO_PIN_2 ); //LED on PF1, Trigger on PF2 (there's also an LED there)
ROM_GPIOPinTypeGPIOInput(GPIO_PORTF_BASE, GPIO_PIN_4);
ROM_GPIOPadConfigSet(GPIO_PORTF_BASE, GPIO_PIN_4, GPIO_STRENGTH_2MA, GPIO_PIN_TYPE_STD_WPD);
while(1)
if (measureD() < 750) { GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_1, GPIO_PIN_1); } //LED ON
else { GPIOPinWrite(GPIO_PORTF_BASE, GPIO_PIN_1, 0); } //LED OFF
delayMS(20);
Mike Szczys
