Seiko Robot Custom Controller
Arduino-based replacement Controller for 4-axis 1983 Industrial Seiko Robot
Cleveland's Hackerspace; Makers Alliance, is creating a custom controller for our 1983 Seiko XY Series 4-axis Robot. The project includes: PSU change, building a 4-axis servo controller, Arduino Mega interfacing servo controllers and sensors, custom board to connect the existing cables to the new internals, shoehorning all of the above plus a PC motherboard into the existing Seiko Robot Controller case.
Orignal Motherboard Connector Pinout
https://docs.google.com/viewer?a=v&pid=forums&srcid=MDQxOTY3MTUxODUzMzQ2MzE2NjMBMTU5MTI4MjIwOTY2NTg0ODUwNzUBNDg2Ry1qTHpPSWNKATAuMQEBdjI
Motherboard Hack Stack
  • 1 × Seiko XY Series 3000 Robot
  • 1 × OEM robot controller carcass; minus all daughtercards Used for: cable breakouts, Motherboard connector research, buttons
  • 1 × Arduino Mega
  • 1 × TI Motor Controllers (currently testing)
  • Encoder Hacking
    Ross Bochnek • 04/10/2015 at 18:04 • 0 comments
    We're more or less satisfied with the oscilloscope readings taken off the A Axis Optical Tachometer. We blew an IR LED, but replaced it from an old remote we had lying around. All the motors have the same manufacturer, and the main 3 axis motors have Optical Encoders rather than the Optical Tachometer we tested with on the A Axis motor (end effector motor). So, we have a good starting point for the pinout and wire colors of the encoders, and know how to power up the IR LEDs with the proper resistor.
    We'll be using a Teensy 3.0 for all servo control, including reading Optical Encoders and messaging our Motor Controller board. Since we're using interrrupts to read the encoder data, we need the external motor controller. We can't Bit Bang the PWM channels to control the motors, since that method affects Arduino interrupt pin timings.
    Here is the proposed motor controller board
  • PLC Case & Panel
    Ross Bochnek • 11/29/2014 at 05:15 • 0 comments
    We are going to use an industrial enclosure that housed Programmable Logic Controller (PLC) Power Supply Units (PSU), relays, and electrical bus strips. I've been calling this enclosure the PLC Case. After removing most of the components, I found that I had to remove a metal panel in order to unbolt the rest of the components. So, I removed the panel from the case, will finish removing components, and we'll decide if we want to continue with a metal panel that has to be drilled and bolted to, and if so, do we want to hinge it it so we can access it more easily. Or, we may want to replace the metal panel with a plastic or wood panel.
    11/26/14
    "We're very close to finishing our Power task list. Let's choose a panel material to mount most of our controller internal onto- stick with steel or switch to plastic, wood, etc. We can reassign power bus strips for 120 VAC, 24 VDC, 24 VDC, 5 VDC, and since we'll eventually have a computer PSU, +12 VDC, -12 VDC, and maybe tap the 5 VDC from it too. We'll wire up our fuse bay, and figure out what we'll use for switches until we put the panel back into the enclosure that currently houses the toggle switches. We may want to install a power strip with breaker onto the panel, so we can get 5 VDC from a small adapter while working, and have the ability to plug in other PSUs to it as we work. We may even want to keep the powerstrip for when we reassemble the enclosure.
    A revised, multitask plan might look something like this:
    • Desolder servo Drive connectors from Motherboard, solder them to a perfboard
    • Solder standard lines of 1/10" center pins onto the perfboard OR connect them directly to the Arduino Mega
    • Mount a motor controller board, Arduino Mega, and perfboard to the panel
    • Take a brushed DC motor with optical encoder that was hacked out of a printer, and try to control it through the Arduino IDE using the Arduino Mega and a motor controller board
    • Simulate end stop sensors or use the ones on the printer if they already exist.
    • Implement optical isolation wherever required
    • Test the Seiko's own the end-stop sensors
    • Connect the Seiko's end-stop sensors to the Arduino and test them in the Arduino IDE
    • Try to implement over-current sensing protection on the Arduino motor test bed as well
    • Then try to interface to the Seiko's A axis servo (end effector motor) using the robot's own cabling connections
    • At some point, try to control an encoded motor using Firmata firmware on the Arduino, and control it with Snap4Arduino
    • Connect a second motor. I'm guessing we'll want to use the 24 VDC PSU to power the A and Z axis servos, and use the 28 VDC PSU to power the X and Y axis servos.
    • Try to control both the A and Z servos accurately with optical encoders, end-stop sensors, and overcurrent protection
    • Get this all working through the Seiko's own existing cabling, and if needed investigate the box on the back of the robot that seems to be am Encoder Amplifier
    • Connect the second motor controller and try to control the X and Y motors
    • Servo Party"
  • Robot Provenance
    Ross Bochnek • 11/05/2014 at 18:19 • 0 comments
    10/11/14
    Our robot was originally purchased by Bell Laboratories in 1983 to test electrical connections within a clean room. Makers Alliance got it through Case Western Reserve University, but we are still researching is it went somewhere between Bell Labs and CWRU.
    11/5/14
    Aaron Humphreys posted: " I believe that I may have uncovered one of the past uses for our seiko. Pretty cool stuff. We might be able to get some documentation from the authors. Forgive the massive link.https://www.google.com/url?sa=t&source=web&rct=j&ei=KQhaVOqCNJKmyATmiIKwCQ&url=http://utwired.engr.utexas.edu/lff/symposium/proceedingsArchive/pubs/Manuscripts/1995/1995-30-Mathewson.pdf&ved=0CBwQFjAA&usg=AFQjCNF0V3WKqfYCDuhcj-uIkFo6BnAn-w&sig2=pZEv8xN11hnwoYu1jOsjAA "
  • New Connector Masterboard
    Ross Bochnek • 11/05/2014 at 18:14 • 0 comments
    11/5/14
    With Aaron, we tried to trace the controller cables. I documented the wirewrap job that had been done, probably at Case, as well as the connectors. Then I removed the offending innards and placed them aside, including an obsolete sort of motherboard. Now, we can make our own masterboard to connect the cables that run to/from the robot arm to its new brain and servo controllers. We also plan to cram this all, plus a PSU and a PC motherboard into the existing controller case.
    I'm calling our new connector board a Masterboard to differentiate it from the PC Motherboard or SBC we're going to also put in that enclosure. Do you think we should identify and shop for the connectors that are on the old connector board, or should we just hot air rework them off the original board to put on the Masterboard? I'd like the Masterboard to have connectors on one or two edges to 1/10"-center IDE ribbon cables or jumper wires, and then most of it, initially could be a huge breadboard. Then, we could replace the breadboard with either a PCB or perfboard that accepts the ribbon cables or jumpers. I can think of a similar way to do it that I won't try to describe here, since I'm sure you'll think of variations. How do you think we should do this kind of wiring so we can both prototype and then move to something more permanent?
    Old Motherboard:
    11/11/14
    I've traced out all of the connectors on the original motherboard, and plan to create a schematic.
    I also found a diagram of the robot's sensors; mostly limit switches, which improve accuracy and prevent physical damage from over travel.
    Let's take a look at the power rectifier board, fuses, switches, and indicators inside the original controller case. The controller originally had 240V AC 3 phase power, and there are so many cut wires that we can either trace them or start fresh with the power. We're using a new PSU anyway.
    I have an idea to put the controller inside one of our PLC cases, and mount a computer monitor on the inside of the door.
    At our meetup on 11/11/14, we'll continue discussing plans for power, case, board interfacing and stacking, how we're going to protect the robot from itself electrically and physically via fuses/sensors/overcurrent protections/E stops, and what I learned about the connectors this weekend.
    OEM Seiko Robot Controller Motherboard
    numbers indicate how many connections to what
    there were 4 servo controller boards, 1 CPU board, and 1 I/O board
    Axis Z
    Encoder Connector
    -5 GND
    -3 to own servo controller board
    -2 unconnected
    Driver Connector
    -2 to own servo controller board
    -1 to I/O board
    -1 to GP
    -1 unconnected
    Axis T
    Encoder Connector
    -5 GND
    -2 unconnected
    Driver Connector
    -2 to I/O board
    -1 to GP
    Axis R
    Encoder Connector
    -5 GND
    -1 unconnected
    -1 axis R encoder connector
    Driver Connector
    -2 to I/O board
    -1 to GP
    Axis A
    Encoder Connector
    -5 GND
    -1 to servo controller board Axis X
    -1 unconnected
    -1 to G connector
    Driver Connector
    -2 to I/O board
    -1 to GP
    Other connectors
    GP
    -1 to each Driver Connector
    -1 to Con G
    -1 to Con 8
    Con G [Gripper?]
    -2 GND
    -8 to CPU board
    -8 to I/O board
    -1 to Axis A Encoder Connector
    -2 to each servo controller card
    -1 to GP
    -3 to Con 9
    -unconnected
    Con 6
    -3 GND
    -1 to a capacitor
    -2 to a diode
    -2 to Con G
    -1 to itself
    -2 to CPU board
    -2 to I/O board
    -1 to each servo controller board
    Con 8
    -5 to I/O board
    -1 to GP
    -1 unconnected
    Con 9
    -2 to each servo controller board (8 total connections: 4 individual pins to each + 1 pins to all 4)
    -1 to Con 9
    -2 to Con G
    -1 to its own pin (that connects to all 4 servo controller boards)
    Con SE
    -4 GND
    -8 to I/O board
    -3 unconnected
    11/18/14
    • Motherboard Hacking: move servo Drive and Encoder connectors/breakouts to chosen PLC enclosure, cut out panel mounts for cable connectors, solder wires to original motherboard connector...
  • Servo Research
    Ross Bochnek • 11/05/2014 at 18:09 • 0 comments
    10/14/14
    Dave figured out that the servo motors only need a minimum of 24VDC, and we're going to use our 30V PSU for testing. Dave has a source for controllers for the motors, and $50 will cover all 4 brushed motors. I think we'll want to control those controllers with a microcontroller, and there are lots of options.
    10/22/14
    There are at least 2 different servos in this bot. Their mutual manufacturer, Yaskawa, is still in business, and I have requested documentation from them about the servos I have identified in the bot so far. They are both brushed, totally enclosed, self-cooling, continuous, DC motors with optical encoders. Their encoders seem to vary in voltage, output waveform, and possibly pulses per revolution.
    The servos are:
    Minertia Motor Mini Series
    UGTMEM-03MC4OE
    Optcal Encoder possibly SJ type
    close datasheet includes: TSE2-C249-1C.pdf
    Minertia Motor RM Series
    UGRMEM-02SDS21
    with
    UTOPI-08ZAH Optical Encoder at 800 pulses/revolution
    close datasheet includes: TSE-C253-10C.pdf
    Most data has so far been found on Yaskawa's own paper data sheets that are probably old, low quality, and have been scanned. In the late 1970's or early 80's, the Seiko robot included motors that probably came after the data sheets were created, judging by their "Design Order" letters C and D in their respective product codes. Hopefully, Yaskawa will find some more updated and higher quality data sheets to send me; even if they have to scan them for the first time.
    11/5/14
    Tonight, Dave uncovered the end effector ("A" Axis) servo...
    Aaron or Dave post an image or the codes from the end-effector servo. I've had some luck finding specs on the servos based on their label codes.
    11/8/14
    http://www.ti.com.cn/general/cn/docs/lit/getliterature.tsp?genericPartNumber=sn75183&fileType=pdfThere is a wire wrapped circuit board I removed from the controller. That was one of the ends that the colorful ribbon cable was connected to, but I can't find what the other end went to. The board only has one type of IC left on it: the SN75153N. Judging by the empty IC sockets with different numbers of wired pins, it had 2 other types of ICs. I think some of the board was used to read the optical encoders of the servos. The SN75153N is a quad differential line driver, and my phone insists on pasting the datasheet link only at the top of this post. Might it have been used to read the optical encoders? I'm not yet familiar with differential line drivers.
    Dave posted:
    The number of wires going to the encoder will help determine what type it is.
    Single Ended usually uses 4 wires. Ground, power, and 2 signal wires.
    Differential usually uses 6 wires. Ground, power and 4 signal wires.
    Single Ended uses the presence or absence of voltage relative to ground to indicate a high or low state.
    Differential uses the relative voltage difference between 2 signal wires to indicate high or low. The wires are not tied to power or ground. They float. They are less sensitive to intereference since stray EMF will affect both wires similarly causing little or no relative voltage difference. You get a higher signal to noise ratio.
    Most everything you see now days is 5V or 3.3V single ended. Occasionally 5V or 3.3V differential.
    Going back a few (many) years you also see 12V, 15V, and 24V with differential being more widely used than single ended.
    20ma current loop was also popular. It is differential but uses current instead of voltage to indicate a high(20ma) or low(4ma) state. You often see current loop used with one side tied to ground (not floating).
    The main design advantage to current loop is that you instantly know if a wire comes loose. With digital circuits, an unconnected pin floats high. You have no direct way to tell if you are getting a constant high signal, or if the wire fell off.
    DC Brushed motors will use 2 wires for power.
    DC Brushless motors will use 3 or more wires for power, sometimes many more.
    Stepper motors will use a minimum of 4 wires, and a max of 8 - except for 5-phase ones that...
  • PSU research
    Ross Bochnek • 11/05/2014 at 18:06 • 0 comments
    10/12/14
    All Electronics has multiple 24v power supplies, but only two 48v power supplies. Would it be possible to wire the following 48v PSU in series with one of our many 12v PSUs to supply the 60 VDC required by the robot's servos?
    The robot already has an air line running to a port by the end effector, and even if the end effector was the only pneumatic device we use, the included solenoid valve should have its own 24v PSU that we switch via relay.
    All PSUs, including 24v-
    http://www.allelectronics.com/make-a-store/category/480/power-supplies/1.html
    48v PSU- $37.75 6.3A
    http://www.allelectronics.com/make-a-store/item/ps-4863/48v-6.3a-power-module-ac-dc/1.html
    http://allelcdn.upshotcommerce.com//mas_assets/theme/allelectronics/spec/PS-4863.pdf
    Their other 48v PSU is only rated at 0.38A
  • Sizing up the Tasks
    Ross Bochnek • 11/05/2014 at 18:04 • 0 comments
    10/11/14
    I have been reading the documentation for our blue Seiko industrial robot. It's different from the large yellow Fanuc industrial robot, but is from the same era.
    The main thing we need to do to make it even remotely usable is to hack the power supply. Although it probably has a power supply that requires 3-phase 220-240 VAC, Seiko used to offer an alternative PSU, and everything internally seems to run on DC voltage anyway. Even without Seiko's alternative PSU, I think we could use a spare desktop computer PSU + another one or two. All the digital logic seems to use 5 VDC, and the analog circuitry requires 12 VDC; both of which the computer PSU could supply. To make the robot move, the pneumatic solenoid valves require 24 VDC, and servo motors require 60 VDC. Once we can provide 60 VDC, we can probably switch it to the servos via relays.
    I'm thinking we may also want/need to hack the robot by providing our own CPU and way of programming it. There are numerous ways to do this, including an Arduino Mega with a computer running Snap or Scratch for Arduino. That way, the robot could be used to teach programming, and almost anyone could do it. We could also get quite advanced, and run Ubuntu with Robot Operating System.
    I don't know how much the robot itself weighs, but it's pretty heavy. An unhacked robot can be really, really precise, so they recommend a very level mounting surface, bolting the robot to its table, and the table to the floor. I don't yet know the robot's encoder protocol, but if we can figure that out, I hope we can still have a very precise robot even after hacking it.
    I'd like to show our EEs some pages in the robot's documentation, and discuss the possibility of finding power supply units and powering the Seiko up.
    11/18/14
    Next Steps:
    • Power: assess which components from the two PLC enclosures are needed to power the servos and the rest of the project; possibly ordering more 24v modules, choosing the enclosure with the most useful configuration and mounting of components, remove the rest, and move the necessary components from the other PLC enclosure into it. Determine how to obtain +5 VDC, 24 VDC, and maybe also +12 and -12 VDC, wire these to rails/bus strips, and label them. Prepare case grounding mount points. Determine which breakers, fuses, buttons, indicators, and key switches to use for the robot controller, and where to mount them.
    • Motherboard Hacking: move servo Drive and Encoder connectors/breakouts to chosen PLC enclosure, cut out panel mounts for cable connectors, solder wires to original motherboard connector pins on the back, so we can use these as both jumper wires to a big breadboard and eventually a shield for the Arduino Mega, connect breakout to original motherboard and mount it upside down on standoffs
    • Microcontroller: Arduino Mega has arrived- purchase or start building a custom shield for it to connect both motherboard wires and motor controllers
    • Motor Controllers: use the dev toolkit to determine firmware for controlling brushed DC servo motors and connecting their optical encoders. Try to control a motor.
    • Robot: determine the need for the rear board- is it an Encoder Amplifier board- OEM or a hack? Should we keep it? If we REALLY can't control the servo motors and encoders, we might consider finding different motor controllers. The VERY LAST resort, and we MUST discuss this if ANYONE is considering it, MIGHT be to retrofit the robot with stepper motors that we know work with the TI motor controllers we have. Such mechanical deconstruction is NOT to be taken lightly, as the current gearing is tight and accurate, and we don't want to mess up the alignment or wind up with any "extra screws".
    • PC Casemod: Aaron had the awesome idea of sticking a PC motherboard, probably with PSU and drives, into the same enclosure as the rest of the Seiko Robot Controller. I think it would be cool to cover up the electronics with strong, clear plastic set deep enough into the enclosure so that we could also mount...
View all 7 project logs
worm959 wrote 04/11/2017 at 02:03 • point
I picked up a couple of Seiko D-TRAN RT 3000 robots.  One looks to be mostly complete, the others are partial.  I don't have the controller units, so getting them working will require following your approach.  What motor controllers did you end up using?  And can I ask, what are you using your robot for?
interactivation wrote 11/28/2014 at 04:45 • point
Thanks for the leads and link, macona. Soon, we're going to test a motor controller that controls 2 motors. If it works well, we'll use another one for the other 2 motors, and the controllers will be controlled with an Arduino Mega from Sainsmart.com.
Jerry Biehler wrote 11/27/2014 at 03:55 • point
You might try getting some Elmo Harmonica or Clarinet series servo drives to control it. They have a pretty decent interface for tuning which is going to be a big problem. There are a few other integrated digital servo drives out there as well like the ones from CNCdrive.com. They are pretty well regarded. http://www.shop.cncdrive.com/index.php?categoryID=79 From there you can control it from just about anything with step and direction outputs.
If that fails I would try an analog servo amp and drive it with linuxcnc. Getting an arduino to do closed loop servos is problematic.
