This is an easier tutorial than my last and it is on homemade rocket engines!
The biggest engine I have made using this method was an I class engine that produced 180N for 2.1 s.
You must begin buy taking a mixture of 65% stump remover and 35% sugar. If you chose to add aluminum or baking powder you would add 60% stump killer, 5% aluminum or baking powder, and 35% sugar.
Next you will mix the mixture with a little water and put it in an old frying pan that you don't want anymore.
With your stove on low gradually heat this mixture for 30 minutes.
And this is exactly how you end up on one of those "lists" that get you probed every time you fly.
I was thinking - your home-made rocket engine looks a lot like cat food in a frying pan.
