1Step 1
You must begin buy taking a mixture of 65% stump remover and 35% sugar. If you chose to add aluminum or baking powder you would add 60% stump killer, 5% aluminum or baking powder, and 35% sugar.
2Step 2
Next you will mix the mixture with a little water and put it in an old frying pan that you don't want anymore.
3Step 3
With your stove on low gradually heat this mixture for 30 minutes.
4Step 4
At this point the fuel should be the texture of mashed potatoes. You now have to prepare the casings by cementing the end cap to the tube.
5Step 5
Take your rocket fuel and fill the tube one inch from the top with fuel and let it begin to cool.
6Step 6
Once the fuel is thick and almost hard take a nail and push it directly down the center of the fuel grain to make a hole.
7Step 7
Now you will need another end cap. Drill a 1/4 inch hole in this and put a 1/4 inch bolt through the hole with the top of the bolt on the bottom.
8Step 8
Take your clay and fill the space around the bolt with it to form a strong nozzle.
9Step 9
Take out the bolt and glue the nozzle onto the tube.
10Step 10
Finally you can add a fuze or an electric ignitor and have some fun.
Howie
