1Step 1
Building the Add on PCB is simple, just a few parts. You can test your build by applying 12V+ on pin 4 and a ground on pin 3 of the 6pin inline wire to board pads. The Beeper should emit a 1 second beep. Building the CAT5 (15") 6pin cables to attach the female 6 pin connectors is critical. Don't mix up the pin numbering. Note the pictures showing pin 6 on both the stock Apache Relay Brd and Display Brd. Also the connector orientation for both cables is opposed, see the pic. Color code: Pins 1 thru 6 as : green stripe, green, brown stripe, brown, blue stripe, blue; on both cables. Org and org stripe unused. Note drawn image in files folder.
Opening the UNPLUGGED laminator is easy using the four bottom corner screws. Remove the two screws to the LED display first, let the display drop inside. Now u can remove the cover easily.
Use a hot air supply (hair dryer) to loosen the hot glue holding the 6 pin ribbon cable in place between the stock Relay & LED display seen in the PIC. Note the pin6 identifier on both boards in the picture. Install the new 6 pin cat5 connectors. Match the add on display connector to the display board and the relay/main connector to the relay board. Rout the cables away from the rollers. Install the LED Display back into its cutout and mount the add on board in the fan cutout using a pair of 6-32 x 1/2" screws. Ensure the push button protrudes thru a slot and is operable without sticking. Also the trimmer pot should be accessible via a slot. Adjust the trimmer CCW to provide for best toner transfer (slowest forward speed). Leave the grey roller cover off to observe the roller operation when adjusting the roller forward/rev setting. If the rollers appear to stop and not reverse, your rev. cycle time is too low, adjust the speed control.
Your modification is complete. Just remove the grey flat piece of metal (with semicircles) on the top cover parallel to the rollers, it is attached via two twisted tabs. It can interfere with the PCB movement.
Note that Tightening the 4 laminator tensioning screws as per PCBFX etc. is NO longer required OR recommended as it can cause the laminator motor to stall and BURN your rollers making lots of smoke. You can laminate super thin FLEX PCB with no tightening now, thicker boards are also accommodated better.
See the sidebar on the page for links to CAD & code files.
