1Step 1
Solder a 2x4 Female Pin Header to the spot right next to the micro controller.
2Step 2
Solder the 2x3 Female Pin Header to JP3
3Step 3
Attach USB to Serial adaptor to JP1 and start up Arduino IDE
4Step 4
Connect the bottom-center + and - connection terminals to a 3V power source (CR3023 Battery, 2 x AA Battery, ..)
5Step 5
Upload your code to the Cumulus Sensor Node (Select Duemilanove w/ ATmega328)
6Step 6
Solder the 16MHz Crystal Oscillator
7Step 7
Solder the 2 x 22pF Supporting Capacitors for the Crystal Oscillator
8Step 8
Solder the 3 x 220 Ohm Resistors (the 3 resistor spots nearest to the Crystal Oscillator)
9Step 9
Solder the 10K resistor next to the JP1 connector (Top)
10Step 10
Solder 3 x 3mm LEDs (Top is Yellow, Bottom Left is Red, Bottom Right is Green)
DatanoiseTV
