A D.I.Y. STUN GUN TO EFFECTIVELY SUBDUE AN ENEMY COMBATIVE
THIS IS INTENDED FOR EDUCATIONAL PERPOSES ONLY!!!
View all 18 components
CLEAN UP YOUR WORKSPACE
Gather your components
We will start with the "multivibrator" or "Oscillator" circuit. It supplies an A.C. Waveform to the "T1" transformer.
you can make a PCB or just solder the legs together
It's not a very complex circuit.
First connect the SOURCE pins together on the mosfets
This is where the - (ground) connects to the Power supply
Then connect the GATE pin on MOSFET 1 to the DRAIN pin on MOSFET 2 using a 220ohm-1kohm resistor
Then do the opposite Connect the GATE on MOSFET 2 to the DRAIN on MOSFET 1 using a 220ohm-1kohm resistor
You will be connecting the two outer PRIMARY leads on your "T1" to the drain pins on your mosfets
the third lead (center lead) on the primary hooks up to the + on the power supply
View all instructions
Jesse Ransom
Mike Rigsby
extremerockets
macduff2
Yes, delete it Cancel
You are about to report the project "EFFECTIVE STUN GUN ", please tell us the reason.
