NRF24L01 (MySensors) Arduino balcony garden irrigation controller
07/03/2015 at 13:22 • 0 commentsAdded NRF24L01 Arduino balcony irrigation controller tutorial.
ESP8266 WiFi gas sensor
05/22/2015 at 14:24 • 0 commentsAdded new ESP8266 WiFi gas sensor tutorial.
ESP8266 PIR motion sensor (Arduino IDE)
04/28/2015 at 21:03 • 0 commentsAdded new tutorial ESP8266 PIR motion sensor
ESP8266 WiFi DS18B20 temperature sensor (without Arduino, Arduino IDE)
04/20/2015 at 10:28 • 0 commentsAdded ESP8266 DS18B20 temperature sensor tutorial.
ESP8266 relay switch (Arduino IDE)
04/09/2015 at 15:46 • 0 commentsESP8266 relay switch without Arduino. Program written in Arduino IDE
ESP8266 NodeMCU door/window sensor
04/01/2015 at 06:39 • 0 commentsAdded new ESP8266 NodeMCU door/window sensor tutorial.
EasyIoT low power sensor board
03/17/2015 at 12:46 • 0 commentsNow we working on EasyIoT low power sensor board. It's size is 18x32mm and it's suitable for remote sensor nodes like door/window sensor, button, water leak sensor, soil moisture sensor, temperature and humidity sensor... Sensor node can easily operate between 5 and 10 years on 2 AA batteries.
Water leak sensor build by EasyIoT low power sensor board.
Current consumption 5.8µA.
WiFi touch screen thermostat
03/13/2015 at 20:45 • 0 commentsESP8266 WiFi touch screen thermostat is example of complex sensor build by ESP8266 EasyIoT Arduino library. We will use Arduino Mega 2560 and TFT 3.2" touch screen display. You will be able to access and control thermostat securely from remote locations.
More details on WiFi thermostat.
ESP8266 LED dimmer
02/24/2015 at 08:36 • 0 comments -
Added automation tutorial
02/07/2015 at 14:30 • 0 commentsWe added EasyIoT server automation tutorial.
EasyIoT
