I've updated the code in the soldering station files. There's new content and an attempt to fix a problem with the PID controlling the temperature around 10C above the setpoint.
Other features:
- Auto turn-off with default time set to 45 minutes;
- If you reburn the frimware, it will use the Kp, Ki and Kd defined in the code instead of trying to load them from EEPROM, unless you run the autotune. This makes it possible to use the soldering station without autotuning.
That's it.
Hi, The link to download the project files is not working. Please update files.
Thanks
The link to the GitHub is working alright here.
Hi
This is a great project. The link to download the project files is not working. can you please update/ fix the link.
thanks
I've reuploaded the files. Try downloading again.
When I have the time I'll check if anything is still broken after the wipe on the VPS.
