1Printing instructions
I found that it worked well when printed in PLA. No rafts or supports needed. 50% fill. 3 perimeters for top bottom and sides. Very little cleanup needed.
Where the throttle wire goes into the lever there is some sag from the printing in this area but with a small amount of clean up the lever works well for its intended purpose.
