Gears for Grandma's Mixer
Replacements for stripped gears in my grandma's old stand mixer.
My grandma's old stand mixer got jammed up and finally broke. Inspection revealed three gears with broken teeth, of which two were identical. Using Fusion 360 and my trusty calipers, I recreated the gears. One of the gears was also the part that holds the beaters, so that took some iteration to get the right fit.
Unfortunately I didn't take any pictures at the time and the mixer is now gone, so I can only post images of the parts from Fusion 360. But it was something similar to this picture I found on google.
Beater Gear v6.f3d
fusion - 3.30 MB - 02/17/2018 at 15:29
Download
Gear 1 v3.f3d
fusion - 1.49 MB - 02/17/2018 at 15:29
Download
Gear1.stl
Standard Tesselated Geometry - 1006.14 kB - 01/18/2018 at 05:02
Download
beater_gear.stl
Standard Tesselated Geometry - 800.86 kB - 01/18/2018 at 05:02
Download
