1. Wire up the ESP-01. To prepare it for firmware flashing, GPIO 00 should be connected to ground before you apply power to the ESP.
2. Visit www.nodemcu.com
4. You can download the actual firmware binaries in pre_built. However, it's even easier if you download the flasher itself because it has the firmware included in there! Get the 32bit or 64 bit version depending on your PC's OS.
6. It should find your FTDI port automatically. Click Flash button and wait till you get a checkmark at bottom left.
7. Quit the flasher app.
9. Use some sort of a terminal program to connect to the FTDI port. I'm biased towards LUA Uploader (I wrote it :-))
10. Write a hello world lua progam.
11. Have fun!
Hi,
How long does it take to flash? I'm getting to step 6 but not getting to step 7.
Thanks
