Max232 and DB9
12/16/2014 at 17:58 • 0 commentsI'm working on the max232 integration and the DB9 connector.
And it's good Rx and Tx are ok.
I'm adding RTS, CTS and I'll try to flash it using USB-RS232 cable
Analog parts
12/15/2014 at 12:21 • 0 commentsI've added the possibility to analyze and view A0 and A1 trinket pins on the screen.
A0 & A1 can be used as inputs, inputs pullups and/or outputs.
IN: input / OU: output / UN: unused
3 modes (A0==UN && A1==UN not a possible case):
- Input mode : (A0 == IN && A1 == IN) || (A0 == IN && A1 == UN) || (A0 == UN && A1 == IN)
- Output mode : (A0 == OU && A1==OU) || (A0 == OU && A1 == UN) || (A0 == UN && A1 == OU)
- Mixed mode : (A0 == OU && A1==IN) || (A0 == IN && A1 == OU)
Oscilloscope screen works :)
Serial configuration
12/10/2014 at 20:54 • 0 comments![]()
ATmega 328p datasheet extract
http://arduino.cc/en/Serial/begin
The firmware will support:
- Speed: 300 / 1.2k / 2.4k / 4.8k / 9.6k / 19.2k / 38.4k / 57.5k / 115.2k / 230.4k / 460.8k / 500k / 576k / 921.6k / 1M / manual value between 300 and 1M
- Data / parity / stopbits:
- None parity:
- 5N1
- 6N1
- 7N1
- 8N1
- 5N2
- 6N2
- 7N2
- 8N2
- Even parity:
- 5E1
- 6E1
- 7E1
- 8E1
- 5E2
- 6E2
- 7E2
- 8E2
- Odd parity:
- 5O1
- 6O1
- 7O1
- 8O1
- 5O2
- 6O2
- 7O2
- 8O2
- None parity:
Battery powered
12/10/2014 at 15:59 • 0 commentsAt the moment, the trinket is powered by battery :)
Left to right: Trinket, battery level switch, charge/battery platform, 4 switchs (Rx/Tx/RTS /CTS to select TTL and/or RS232 level on each line)
Middle right: Trinket power switch (On/Off)
Main PCB board
12/09/2014 at 20:14 • 0 comments
Cut protoboard![]()
With screen mounts, trinket and charge/5V module
Screen holder test
12/09/2014 at 11:52 • 0 commentsI'm now 3D printing a screen holder test part. (ABS)
It's good. I have now the good screen size. -
Serial test
12/04/2014 at 21:20 • 0 commentsComputer (Minicom) => USB-FTDI <=> Rx/Tx <= Trinket (Screen)
Computer:
TSPT
Trinket and screen test
12/03/2014 at 18:36 • 0 comments
I'll use it in SPI mode, so I have to solder closed IM1 IM2 and IM3 bridges (not IM0)![]()
Screen pinout Trinket pinout GND G Vin 5V 3Vo N.C. CLK 13 MISO 12 MOSI 11 CS 10 D/C 9 RST RST Lite N.C. GND N.C. IRQ N.C. SDA A4 SCL A5 IM3 N.C. IM2 N.C. IM1 N.C. IM0 N.C. CSS 4 CD N.C. ![]()
It works :)
Pro Trinket 5V
12/03/2014 at 18:33 • 0 comments![]()
Screen 2.8"
12/03/2014 at 16:48 • 0 comments
Size: 82mm * 62mm * 8mmUseful: https://learn.adafruit.com/adafruit-2-dot-8-color-tft-touchscreen-breakout-v2
Cut protoboard
