1Step 1
Take the speaker, making sure the wire is stripped so that is can be inserted into the arduino and held in place by the pins in the screen shield, and place the ground into the ground and the other into dig. pin 9 of the arduino.
2Step 2
Place the screen shield onto the arduino.
3Step 3
Plug in the battery pack.
4Step 4
Attach all of the parts into a small package.
5Step 5
Download the files from http://blueokiris.webs.com/ under the Ternex OS 2.0 tab. Rename the file to "Ternex OS 2.0.zip". Extract all files.
6Step 6
Upload the GAMEDUINO.ino (Ternex OS) to the arduino from the folder that appears
7Step 7
Copy all files from the SD Card folder onto the SD Card.
If you want to add another game to the device, then drag it onto "FileListAdd.exe" on the SD Card, and it will be added to the file list stored on "flist.bin".
8Step 8
Insert SD Card into device and turn the device on.
