Lightning Direction Finding
Finding the direction of lightning strikes.
In an old Scientific American "The Amateur Scientist" column, there was a device for finding the direction of lightning. I really love lightning, and I would have loved to build it, but the plans used CRTs and tubes, so it was nearly impossible.
What did make sense, however, was that the signal received was an audio-frequency electromagnetic signal.
My idea is to build a loop DF antenna and connect it to a phono preamplifier, and feed the signal to the stereo sound input of a PC. From this information the strength and direction of a lightning strike should be determinable.
DFSound.nb
First attempts to read sound date from a PC port.
nb - 9.09 MB - 01/22/2018 at 22:07
Download
stong1963.pdf
The original article that piqued my interest.
Adobe Portable Document Format - 908.16 kB - 01/20/2018 at 12:39
Preview
  • Wrong pre-amplifier
    Niel Malan10/02/2020 at 18:55 0 comments
    I have abandoned the idea of using the phono pre-amplifier I described in a previous post. I realized that the use of shielded feedlines greatly complicate the design of the loop antenna, and that a balanced feed can be conveniently conducted along Cat 5 cable.
  • Mathematica in Stereo
    Niel Malan01/22/2018 at 21:42 1 comment
    Today I tried to input sound into my laptop and process it with Mathematica.
    It seems to work OK when I use the built-in microphone or a headset, but not so well when I try to input two channels.
    My Dell Inspirion 15 has a only a single 3.5 mm socket for sound input and output, and somehow I must convince it to take two channels of line-in.
  • Microphone preamplifier
    Niel Malan01/21/2018 at 20:02 0 comments
    This is the amplifier I plan to use in the project. I got cheap at a hamfest in Aberystwyth, Wales.
    It has a nice metal box, so shielding should not be a problem. Nice sturdy microphone plug inputs, but RCA connectors for the output. I'm not very fond of those, so I might change it.
    The whole thing is very much 20th century inside. Only four transistors and a bunch of resistors and capacitors inside. The transistors are 2SC2240s, which seems to be the right choice.
  • Useful Information
    Niel Malan01/21/2018 at 10:32 0 comments
View all 4 project logs
James Finch wrote 01/21/2018 at 12:21 point
This site inspired me to look into higher relative permeability materials for smaller size antennas: http://stormwise.com/
This wiki details different materials: https://en.wikipedia.org/wiki/Permeability_(electromagnetism)
TheotherMike wrote 01/19/2018 at 20:09 point
Or, use an AS3935 lightning detector chip...  ;-)
Niel Malan wrote 01/19/2018 at 22:28 point
Ah, we'll test that chip to see how reliable it is!
TheotherMike wrote 01/20/2018 at 09:37 point
Using it outdoor with batteries works quite well ! Damping inside is a litle bit too much.
There´´s quite some info available, e.g. :
https://www.instructables.com/id/Arduino-Pocket-Lightning-Detector/
xof wrote 01/19/2018 at 17:51 point
See also http://BlitzOrtung.org . It is an open network for worldwide strikes localization.  It is based on GPS time synchronization and time of arrival of https://en.wikipedia.org/wiki/Radio_atmospheric
Niel Malan wrote 01/20/2018 at 07:22 point
Thank you! I'll add a link on the project page.
