Because I have to archive the cache, I decided to share the technical setup of its field puzzle.
You can find the original cache description here: https://coord.info/GC63B4V (German only)
Your task was to find the release month of the first public WIFI hotspot in Linz/AT.
The answer could be used as part of an email address. Sending an email to the correct address will broadcast a temporary SSID at the original cache location. The SSID contains the coordinates of the final cache location.
sehaas
Martin
Sheetal Dalal
Thaddaeus
