And now with video!
A project log for TTTOTP
Tiny Trinket Time-Based One-Time Password
colonwqcolonwq • 01/02/2015 at 17:14•0 Comments
I have added a video of the start up of the device and the generation of two TOTP codes. The first half of the code is displayed while the button is pressed. The second half is a fixed amount of time. You can generate the same code twice if you press the button within the same 30 seconds.
