I have mounted the board on an Adafruit Permaproto Breadboard sized for an Altoids can. This was my first time using one of these boards.
I have learned a few things:
- Don't run the wires from point to point. Routing is better.
- Mind the soldering iron shaft. I scorched a couple of wires.
- Get more colors of wire. Yellow, yellow and yellow are not enough.
- Test mount everything with stacking headers. If it all works, remove the headers
