My friend has a four channel phase angle dimmer pack but no real way to control it. He'd like to use it for band shows but not have to babysit the board of switches he has rigged up. This project will let him attach a programmable chaser to the input of the dimmer pack and get on with doing other things.
The circuit works by bumping a ten volt signal from any analog light control interface in an arbitrary pattern, programmed with pushbuttons on the board. An MSP430G2221 controls the patterns and interface.
The onboard ten volt regulator (a humble LM317) allows this board to be used without another analog controller in the system.
Details
Interface
0 to 10V intensity
Channel Count
4
Input Voltage
12 to 15 VDC
Components
1×
MSP430G2221
Microprocessors, Microcontrollers, 16 bit
1×
LM317
Power Management ICs / Linear Voltage Regulators and LDOs
