Exploring different methods of using the WS2812 protocol
I recycled components from old builds to make this 3-pixel test rig. It will plug into the bottom headers of the Tiva C launchpad using vbus, gnd, and PD0.
I'm thinking of using a TIVA C Launchpad as the first hardware platform to drive these. This has a chip that can run at 40 MHz (using external crystal to drive the PLL).
There are 5 timings for the ws2812S:
If I can run a timer with two different compare interrupts I can use the following values:
Interrupt scheme:
Take a look at
https://github.com/cnlohr/ws2812esp8266
The Esp8266 can run at 160 MHz ...leaving plenty of time for making fun patterns...
