Big Update
07/13/2014 at 10:57 • 0 commentsMounted the linear rails for the Z-axis:
Mounted the Z-axis ballscrews:
The entire system:
The next step is to mount a big plate on the ballscrews and the linear shafts. -
Another Test Video
04/25/2014 at 07:51 • 0 comments -
Mounted the motors outside
03/31/2014 at 06:49 • 0 commentsNow the Motors for the X-Axis are mounted outside, so the Working-Area gets bigger.
Added a small Z Axis and a Pen
03/26/2014 at 07:34 • 0 commentsI've added a small Z-axis out of an old DVD-Drive and hoocked it uf to my CNC. At the z-axis i mounted a pen, so now my machine can plot pictures on a Paper or flat surfaces like my "Sprit" or alcohol bottle.
First test-video of the my CNC
03/19/2014 at 06:18 • 1 commentHere is the first test-video of my CNC, in this Video, i couln't controll the laser, but at the moment it works. This is a normal violet laser who writes on a glow in the dark surface.
Here is the Video: http://youtu.be/Xan15t2EbFY
Added the Y-Axis and running some tests
03/17/2014 at 07:27 • 0 commentsNow the Y-axis is added to my PCB-Mill and the belts arrived so i dont't have to use those
shoelaces again. The entire system works pretty good. Test Video is comming soon!!! -
Testet the X Axis
03/10/2014 at 18:47 • 0 commentsFirst Test of the X-axis was succesfull. The axis don't have a belt at the moment, because they didn't arrived at time, but a sholace will works fine ; ). Next step is to Design the new holder for the y-axis linear shafts, with a included beltholder.
ebrithil
