This is for those who need motivation to keep a constant high pace while jogging. Play a playlist retrieved from an SD card at volume dependent on your pace.
In the first iteration of this project I will use an arduino UNO with a sparkfun mp3 player shield and and a sparkfun accelerometer to match. In the second (and probably final) iteration I will swap the uno for a trinket and the sparkfun mp3 with corresponding breakouts.
Glory and people-of-your-preferred-sex are just around the corner.
In the first iteration of this project I will use an arduino UNO with a sparkfun mp3 player shield and and a sparkfun accelerometer to match. In the second (and probably final) iteration I will swap the uno for a trinket and.
Chris Perivolaropoulos
Jean Noel
DiPDoT (Brian)
Tachyon
