Hackaday.io Hackaday.io
Sign up Log in
Blinkenschild
A portable shield that can be used in various scenarios where one of them is subversive rebellion on the streets.
overflooverflo
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
8 comments
335 followers
  • Description
  • Details
  • Files 0
  • Components 6
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 8
View Gallery
308
8
335
29
Team (1)
  • overflooverflo
Join this project's team
  • Metalab Project wiki
  • Blinkenschild Source
metalab hackerspaceshop schild schield Demo
Related lists
Blinkenlights, LED Displays & Matrices
Projects which display data or convey information through blinky lights
This project was created on 03/10/2014 and last updated 12 years ago.
Description
One day i woke up with the urge to rise up and stick it to the man.
And what would be more suitable for that job than blinky lights eh?
I used:
960 RGB pixels - RGB-123 ( http://www.hackerspaceshop.com/ledstrips/rgb-123.html )
a microcontroller - teensy 3.1 ( http://www.hackerspaceshop.com/teensy/teensy-3-1.html )
a bluetooth receiver (http://www.hackerspaceshop.com/teensy/teensy-3-1-bluetooth-module.html)
a SD card slot (http://www.hackerspaceshop.com/teensy/teensy-3-microsd-module.html)
lots of LiPo
and a custom Android.app
The main documentation for this project is on the metalab wiki. ( https://metalab.at/wiki/Blinkenschild )
Over 200 hours of work went into this "weekend project" but the result is pretty groovy.
We even made a video with a horse for reference.
Details
Components
  • 15 × RGB-123 64 Pixel WS2812B-10 Board (http://www.hackerspaceshop.com/ledstrips/rgb-123.html)
  • 1 × Teensy 3.1 A very small powerful microcontroller (http://www.hackerspaceshop.com/teensy/teensy-3-1.html)
  • 1 × Micro SD card slot http://www.hackerspaceshop.com/teensy/teensy-3-microsd-module.html
  • 1 × Bluetooth Serial module http://www.hackerspaceshop.com/teensy/teensy-3-1-bluetooth-module.html
  • 1 × Wood, Acryl, Spraypaint, Foam inlay, Aluminium profiles
View all 6 components
Log In/Sign up to comment
Sign up with Github
OR
Roman M wrote 03/06/2016 at 13:30 • point
Link is live. Search for Magic Pixel on Kickstarter.
Roman M wrote 03/03/2016 at 21:52 • point
See amazing LED project here: http://kck.st/1Oi2sHC
Simply and affordable...
overflo wrote 03/03/2016 at 22:05 • point
Broken link. Could this be spam for a kickstarter campaign?
josephchrzempiec wrote 09/21/2015 at 02:36 • point
How many leds are going across and down?
Zardoz wrote 07/25/2014 at 15:32 • point
This a real GEM of a project !, I can see this taking off sometime, 21st century protetestors, all it needs is a few hundred perps to get airplay
Eric Evenchick wrote 04/04/2014 at 15:31 • point
Nice sign, bonus points for the HaD logo :)
Did you have any issues with hooking up 15 LiPo cells in parallel? It looks like you have a bunch of them going into a junction box, what's inside there?
overflo wrote 04/04/2014 at 15:55 • point
hey,
the RGB-123 use WS2812B-10 leds
the datasheet rates them between 3.5 and 5.5v
some guys had trouble running WS2812B at 5V with 3.3V signal levels.
turns out the WS2811 datasheet says that the signal / power ratio should be no less than 0.7.
running the whole setup at 3.7-4.2V from the lipos means that we are well within the 0.7 ratio with our 3.3v signals.
thats why i run them DRIECTLY from the lipos and use no levelshifters or step-up converters anywhere.
the box is just a bunch of JST connectors and fat wires to transport the current away safely.
everything worked out much better than expected :)
Eric Evenchick wrote 04/04/2014 at 16:30 • point
Ah, I guess this would work out fine if they are all charged to begin with. I would be worried about mixing LiPos with different states of charge.
Various Famicom compatible cartridges, each containing a sound chip
Project Owner Contributor
Famisyn Cartridges
david-viensDavid Viens
This project is customizing the canopy of the nano drone.So the drone get character and personality.And fun for us :)
The BAT
ramkumar-rRAMKUMAR R
A hydroponics station with a companion web app.
Project HydroGrow
bobby-christopherBobby Christopher
Supplyframe DesignLab: 2022 Hackada…
This floppy disk can hold 512GB!
The 512GB Floppy Disk
franklinsteinFranklinstein
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Blinkenschild", please tell us the reason.
Send message
Remove Member
