Wiring up the picture maker
12/16/2014 at 23:32 • 0 commentsDay 1, parts are here, and I'm playing with this cool OLED display from Adafruit. My goal today is get a logo on there, and maybe some sample text that will eventually show ping statistics. After this is complete I'll follow the outline in the project roadmap and move SPI pins around.
13 is going to RST for OLED, but is used as SCK for EtherCard sketch, will assign something else for RST
~10 is CLK on OLED, that will be changed to 13
12 is SS on OLED, this will be MISO, will pick something else for SS
~11 is "D/C" (data/command) on OLED, I don't know that is (SI?)
8 will be used as SS for EtherCard
Notes:
Connections for ethercard on UnoSCK - 13 (19/PB5/PCINT5/SCK)
SO - 12 (18/PB4/PCINT4/PWM/MISO)
SI - ~11 (17/PB3/OC2A/PCINT3/PWM/MOSI)
CS - 8 (14/PB0/CLK0/PCINT0/ICP1)
OLED display on SPI
https://learn.adafruit.com/monochrome-oled-breakouts/wiring-1-dot-3-128x64
GND goes to ground
Vin goes to 5V
DATA to digital 9
CLK to digital 10 (SCK)
D/C to digital 11
RST to digital 13
CS to digital 12
chris0x00
