Connects to your computer using DisplayPort/Thunderbolt
Takes 12V 1A input (9-12V recommended)
Consumes a nominal 6W
ATmega32u4 microcontroller
TPS61176 backlight drivers
LMZ12001 high efficiency buck regulator
All spare IO pins available on 0.1" pitch headers. This includes 6 analogue pins, 9 digital, I2C, SPI, serial and 5V power
RGB LED for OSCAR status
Freddie Temperton
mircemk
Clint Stevenson
John Basista
Alex
By August 20th you must have the following:
- A video. It should be less than 2 minutes long describing your project. Put it on YouTube (or Youku), and add a link to it on your project page. This is done by editing your project (edit link is at the top of your project page) and adding it as an "External Link"
- At least 4 Project Logs
- A system design document
- Links to code repositories, and remember to mention any licenses or permissions needed for your project. For example, if you are using software libraries you need to document that information.
You should also try to highlight how your project is 'Connected' and 'Open' in the details and video.
There are a couple of tutorial video's with more info here: http://hackaday.com/2014/07/26/4-minutes-to-entry/
Good luck!
