All of us who work on Hackaday.io are reading your feedback. If we don't get back to you individually, know that we read what you wrote. Thanks for taking the time to give us feedback, we really appreciate it, you help improve the site every day!
Bugs, Feature Requests, Wishlists
No trick. There is a auto cut off, but I think it's after 4k+ characters. The person who created the content can manually add a break using the editor (more tag), but there's nothing a reader can do at the moment.
Thats alright :) Just what i searched for ;-)
But it works only on the Profile Page?
On
https://hackaday.io/pages/2796 its not "read more" ed.
Can you please resize the images of commenters? I've noticed that there is already a resizing link on your platform, but it is not used often. On hacker pages the profile picture is supposed (?) to be resized by sending get parameters like "r=x&s=400" (sometimes massively repeated) - does NOT work - but the actually working thing https://static.hackaday.io/images/resize/64x64/ seems to be used on gallery pictures of project pages. The team list pictures are not resized on project pages, like the hacker picture below the project title.
Discussion because of speed performances can be found here: http://hackaday.io/project/37-feedback-hackaday-projects/discussion-13555
Hi Dave,
Thanks a lot for letting us know. We already started working on fixing this. Last week we introduced CDN, and ~ 80% of the images are now served from https://cdn.hackaday.com/... Page load time is much better now for east coast US / Europe / Asia. Soon we will have all images served from CDN and as soon as we test we will have css/js served from CDN as well. After that devs will work on resizing images on page itself using /images/resize/XxY/... (for example team members avatars etc). This should all happen in next 2 weeks. I will keep you posted here.
Aleksandar
Thank you for your reply! It's good to hear that you are working on this and have a plan :) It seems to be the static server and the main server that are slow now. www.dropbox.com /s/it3r0cv2w05iiw7/Screenshot%202015-02-09%2013.28.06.png?dl=0 - those images block the whole page and the jquery stuff starts on document ready, so the site is not useable for more than a minute - no quick following/skulling possible.
Hi Dave,
Thanks a lot for your effort ! So in a mean while we moved all images to biggest CDN and they should all be served now from cdn.hackaday.io. We also did compression (gzip encoding) of all content application/javascript files (this content type was missing from web server gzip config :p). We are still working on having CSS / javascript served from cdn as well as resize of avatars. Hopefully that should be in production in 10 days or less ;-) Thanks for following this up!
Aleksandar
Hi Dave,
We are almost done with this phase of optimising content delivery. All static content has been moved to CDN, and image have been resized - also external images (like gravatar). Can you please re-do the speed tests and report us back if something is still slow ;-)
thanks a lot!
Aleksandar
https://developers.google.com/speed/pagespeed/insights/
http://tools.pingdom.com/fpt/
Those are the tools we used for the speed tests and they are giving some really helpful information how one can achieve better load times. Great work with the CDN etc., much better loading times now! I'm still wondering why it crashed all of a sudden, when it worked so good before - but that seems to be just a normal day in the life of a developer. Thanks for the update!
that's about the loading time I got and now get when I open more than one tab. Sometimes those tabs don't even finish loading the css.
just to make this independent of my computer/connection:
http://tools.pingdom.com/fpt/#!/eMbImL/https://hackaday.io/project/37-feedback-hackaday-projects might be a bit wrong because of all the big un-cached pics, so here is an url for a non-pic-heavy-page: http://tools.pingdom.com/fpt/#!/bhUHSb/http://hackaday.io/stack (just compare several 100ms per hac.io item vs. other domains/servers)
Google PageSpeed is red with 17/100 points, there is some optimization possible ;) But those pictures don't explain the loading time of project pages with less pictures.
Edit: 2 seconds for 400kb on the stack page seems a bit long, too.
Hi, I might find a copycat of Hackday.io
They just moved projects here to their website and change the Designer's name.
Hope you be aware of them.
http://www.pcbway.com/project/share/Connect__to_an_atomic_clock_in_space__GPS__DCF77.html
http://www.pcbway.com/project/share/level__A_New_Kind_of_Radio_Module.html
Wow. They blatantly copied parts of the site, including the Hackaday logo for the skulls counter, as well as the users' content.
Hello rayfone, thanks for letting us know. We'll look into it.
[bug] [comment permalinks]
When I click a link to a new comment from my feed, I usually have to scroll down quite a bit to bring the new comment into view. I suspect this is because it initially loads scrolled to the right position, and then the images load, pushing the comments down, but I haven't observed this directly because I usually open everything interesting in my feed in a new tab and then go through them all. (Out of two new comment links I clicked just now, one with many images in the details/logs required a lot of scrolling, and one with no images but one embedded YouTube video required no scrolling.)
My guess is that this is a chrome problem, not a hackaday.io problem - chrome doesn't wait for the page to be loaded to jump to the anchor.
I see the same behavior on my side, same procedure.
You know, that's quite likely. I thought it worked as I'd like it to a while ago, though—maybe Google changed something? And I've also seen a few where it loads scrolled to a position below the comment. I wonder if there's a way to put placeholders on the page so the browser knows how big they'll be before they load…
I am having a really annoying problem. Whenever I want to see my feed or a global feed, I get "502 bad gateway" error. I don't think it's my local problem, since the problem occours both at my work place and at home. It's really annoying.
Hello David, I've submitted a ticket for this. We'll be in touch if we need more details.
Is anyone else having this problem? If so, do let us know.
I am loving this interface for projects. re: search results
when the result is something like a project log, there isn't any info about who it's published by or what project it's attached to. It would be nice to see that.
Hello Jeremy, I noticed that oversight the other day. The update should be out soon. Thanks for letting us know though.
Add option to the sort dropdown for "random" to help discover more projects.
Interesting idea. You don't find new or recently updated a good way to find new projects?
I should have clarified: "re"discover old projects : ) I guess if they're not recently updated or highly skulled, they're probably not that interesting (or died early).
Okay, yeah, so you're going to have to add a link to 'account settings' somewhere on this website. It is completely inaccessible from the main site. I had to return to the spam email you sent me to find a link to it, that is not okay.
For anyone else who has this problem, http://hackaday.io/settings is the link. You really can't get there through this website, unless it's just very well hidden. In which case, *it shouldn't be.* I have no idea what 'Lists' or 'Stack' are supposed to be, and I really don't care - but there ABSOLUTELY should be a link to account settings up there.
"Send me emails when..." should all default to 'no', also. The default is currently 'yes, receive all emails', which is backwards and really obnoxious.
First: I don't work for Hackaday, so these are just my opinions and suggestions.
1. It's not hidden at all. If you have a screen of normal desktop width, point to your picture at the top right (just to the right of the feed and messages icons). That will produce a menu; click "edit my account" or "edit my profile" depending on which settings you want. If you have a narrow screen, you'll see a "Menu" button at the top right instead of the individual icons. Click that and look near the bottom for the same settings links. (If that doesn't work, make sure JavaScript is enabled. The normal-width-screen version works without JS enabled.)
2. Lists are these; Stack is this.
3. The rationale for having emails on by default might be that lots of people sign up just to follow a single project's progress—this is the case with #PortableSDR, for example. Those people aren't going to check the site often, so emails work better for them. And because they don't visit the site often, they might not realize they can turn emails on. People who are on the site more, and so don't need the emails (because they use the feed), are more likely to go through the settings, and turn emails off.
Please add an 'unsubscribe' button to your emails, I really don't appreciate having to log in to this website to stop receiving them. And I've been looking for a few minutes, but don't see any link to where I might be able to unsubscribe.
This should be an extremely simple process, you are just pissing people off as they attempt to walk out the door. That isn't a good thing to do.
Hello carbohydrates, you are right. It's been highlighted recently that the 'update subscription preferences' or 'unsubscribe' links on the emails link to the signin page when you are not logged in. We're sorry this has caused frustration. We'll look into making it easier.
I think @PointyOintment has kindly pointed out in your other comment how to get to account settings. Let me know us know if you have any other questions.
Great idea, could help with some polish though. How do I see what and who do I follow? I was asked to follow 3 projects (out of single page of choices) and 3 fellow hackers (again, single page). Now I want to unfollow these to replace with more meaningful choices, but I can't see option to see list of projects and hackers that I did follow ouf of persuasion. There is the feed, but it does not have them all, instead it seems to be containing site development news???
On your profile, look in the "Projects I Like & Follow" section for projects (though it doesn't provide separate lists for skulled vs. followed), and click on the number below "Following" below your profile picture for hackers.
Thanks! That does it at least for the projects. Will search more for followed people.
I still cant edit my profile. Still get 502 Bad Gateway when I click save no matter what browser I use.
Can you make the "Blog" link actually link to the blog
Ah yes. We didn't update it after the Hackaday.com redesign. I'll get that sorted now. Cheers.
I've listed other folks on projects as collaborators, but I'm not sure how the function really works. Any way to set up a project so that multiple collaborators can add project logs or contribute to content, or is it always tied with one profile?
Hello Zakqwy,
if you add people as collaborators they should be able to edit details, and add logs or instructions. They can't add other collaborators or edit the project description, only the project owner can do that.
You can add collaborators when you set up the project, or by using the 'Edit project' link at the top of the project page when you are logged in.
Let me know if you have any more questions.
Jasmine
signing in, completing a profile is frustrating and doesn't work!
I've tried having you "reset" my password, in the end I had to sign in using twitter.
Creating a profile was bullshit, it kept telling me a URL wasn't valid, just not which one!
resolution issue, when viewing with a 1080x2560 resolution (as in 2560X1080 turned sideways), the images on project pages don't look right
I understand this is an exotic resolution, just informing you in case this wasn't known
It would be useful to upload small lightweight files in the project page such as source code, cad drawing PDF of the circuit board, etc...
Unfortunately we don't have that at the moment. Many people use github and link to that. You can put code examples in the project logs. Would be nice to have it all in one place though.
Is there any way to prevent the comments from flooding My Feed?
Sorry, not at the moment. If you follow someone or a project, you get the comments.
You can prevent comments from *appearing* in your feed by setting them to invisible with a CSS rule. (Use Stylish or an equivalent extension to apply your own CSS styles to the site.) However, this will not actually remove them, only hide them, so pagination (which is server-side) will still be done with them included, resulting in a variable number of entries per feed page. I did this for "so-and-so followed…" entries ages ago, though I think those have since been actually removed from the feed.
That's ingenious. btw - we are going to implement feed settings soon, so you won't need to do that for much longer.
could also be related that I've used up my highspeed web on my phone and have the crappiest download rate now.
Chad
François Ubald Brien
tyler
Is there a trick to "break" (Just show them until a "Break") Pages, Logs etc.?
If someone creates lenghty Posts, the Comment Section on the Pages is far down :-D
