All of us who work on Hackaday.io are reading your feedback. If we don't get back to you individually, know that we read what you wrote. Thanks for taking the time to give us feedback, we really appreciate it, you help improve the site every day!
Bugs, Feature Requests, Wishlists
Hi! Yesterday I created small hackaday.io project ( https://hackaday.io/project/168551 ) from my old project published in russian here http://stanson.ch/index.php?page=proj&proj=EtherPIC (use translate.google.com, if in doubt) long time ago. I thought that this simple hack allowing to add Ethernet connectivity to nearly any small modern MCU without any additional controllers like ENC28J60 will be interesting for hackaday audience. However, that project was deleted after a day, or so without any reason and notification. What's wrong? Not a hack? Some illegal content? Too easy? Please be more specific when deleting projects.
Hmmm. Project is back, thank you, but I still have no clue what I did wrong and what is going on.
It may have been auto moderated and then corrected. No content will be deleted unless it is confirmed spam.
Hello, first of all I would like to say that I really like this platform. However I am currently having some problems with the alignment of images in project logs. When I set an image to align right and save the project log it goes back to the center, if I try to edit it again it is set back to none. Is this a known issue? Thanks, Bram
I think that it would be interesting to have a light theme on here... or at least the option to use one.
Inline images in all my pages aren't visible although looking at the HTML the IMG tags are still there. An example:
Problems with the content server?
Seems to be ok again. Maybe the content server was unreachable from the shopping centre WiFi I was using.
The non-highlit text is VERY hard to read due to low contrast. Is there a way to fix that in our profile?
Example: the text which follows your name starting with 'wrote'
Yes. Is there a way to change that color or the color scheme or? I didn't find one.
Hi, I've got a project with some build instructions, and I don't seem to get an email notification when someone leaves a comment on the build instructions. I don't know whether that's a bug or not, but it would be useful because otherwise I end up accidentally ignoring questions about the build. Thanks! The project is https://hackaday.io/project/164521-drumkid-aleatoric-drum-machine EDIT: Actually it's not just comments on the build instructions - I think I'm missing notifications for comments more generally, even on the project as a whole.
Will check on this and PM you with questions, thanks
If anyone else missed a verify email when signing up please post here.
I once started Hackaday.io via the Github login method, but as Hackaday grows more and more important for me, I wish to split it up and create a separate e-mail-login for Hackaday with individual password. I just cannot find a function to do so !
There's no option for remediation if have a log in error. I expected an email address I could contact or a notification would display an error or something, but I just get redirected to the vanilla log in screen.
I can't log in using my github which shares this accounts email address. I should be using hackaday.io/lirothen right now. I can spam the log in button and all that happens is eventually a redirect to github which prompts that I re-authorize SupplyFrame OAuth due to excessive log in attempts -_-
I signed up today, however I was not able to put a dot into my username, I wanted to be known as angel.o.sphere :D Got the error message: only alphanumeric chars allowed (but the description of the field username says: dots are allowed).
how about capturing card when the dealer flips the card over. Can rainman 2.0 be put on new cell phone?
Would be awesome to be able to embed PeerTube videos. They're open, they're federated (ie, has an API), and they're not subject to the whims of some algorithm no one understands. Presently I'm trying to move my videos to Diode.zone but need to keep YT just to embed here.
Is this change valid for all control servos? I own a CYS8218 servant. Try different changes but the result is always disappointing. You propose to make these connections. I'll try tomorrow. For the moment, thanks.
Just checking, was this reply supposed to be on another project?
My project doesn't seem to show up in any of the feeds, or recent projects. I originally made it private, and then I fixed it to be public, but now nothing I do makes it show up in the feed. Is there anything I can do?
Leave the project public, it should be displaying in recent projects now. There are some anti spam measures in place for new accounts, anything you create from now on should display rather instantly.
Feature request: Add a clearly visible mark over the "miniature view" of the project to show its complete/ongoing status, for instance a yellow/green dot.
Hey can you clarify which is the miniature view? I understand the status icon part.
I could swear I have posted an answer some days ago, but then again, the " miniature" is the cover photo, that is somewhat cropped around the edges (hence smaller than original)
hi,I can not find "views" in the page of my Project ,Only "comment","follower""likes" exist,I am not sure why.Could you give me some hint abouti it ?
https://hackaday.io/project/167094-199usd-3d-scanner-holographic-3d-creater-yscanner
It will be there soon. View count isn't displayed until the project is a few hours/days old and/or has a certain amount of views!
In the past the project page could be sorted by time period (week, month..alltime) combined with current filtering methods like most viewed ect.
Why dispose of such a feature?
As far as I know, only the likes sort has had this function, https://hackaday.io/projects?sort=skulls&range=month
I do see the value of having it for others, for example most views/comments/followers.
Greetings and good morning. When I click on the Tindie Cybersale advertisement on the My Feed page I am getting 404 error. The Link is pointing to https://hackaday.io/tindie.com/sale . It is different when I am on the Global Feed. I don't see a way to include a screenshot, so I'll leave it at that.
Now the sale advert on the global feed is sharing the same 404 link. :-/
